Getting linearValveFvMesh to work in 2.2.x
Like Tree1Likes
  • 1 Post By mturcios777
Old   July 31, 2013, 14:39
Default Getting linearValveFvMesh to work in 2.2.x
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello fellow forum users,
I've been looking to get some of the topology modifiers working in the official stream, and one that is included with the install but which I have yet to see is the sliding interface. Since we've been successful in getting layers and attachDetach, I figured we could tackle this one.
src/topoChangerFvMesh includes a mesh class called linearValveFvMesh which is not compiled by default because it hasn't been updated. I've included an amended version that does compile, but I'm not sure if its completely correct. Copy this version into src/topoChangerFvMesh and change the Make/files to include this in the library.
The case I have uploaded is a simple geometry, with a small passage opening into a larger one. The smaller passage slides along the edge of the large one, and under my current understanding of the sliding interface should detach, move, then reattach. When I first start a case with moveDynamicMesh, the first time step executes, and then I get the following error:
Time = 1e-05
linearValveFvMesh: attached!
Decoupling sliding interfaces
--> FOAM FATAL ERROR:
Face 123191 reduced to less than 3 points.  Topological/cutting error.
Old face: 4(42911 58572 58761 46223) new face: 2(42911 46223)
    From function void slidingInterface::decoupleInterface(polyTopoChange& ref) const
    in file slidingInterface/decoupleSlidingInterface.C at line 348.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Foam::slidingInterface::decoupleInterface(Foam::polyTopoChange&) const in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#3  Foam::slidingInterface::setRefinement(Foam::polyTopoChange&) const in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#4  Foam::polyTopoChanger::topoChangeRequest() const in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#5  Foam::polyTopoChanger::changeMesh(bool, bool, bool, bool) in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libdynamicMesh.so"
#6  Foam::linearValveFvMesh::update() in "/home/gandalf/OpenFOAM/gandalf-2.2.x/platforms/linuxGccDPOpt/lib/libmyTopochangeFvMesh.so"
 in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/bin/moveDynamicMesh"
#8  __libc_start_main in "/lib/libc.so.6"
 at /home/abuild/rpmbuild/BUILD/glibc-2.15/csu/../sysdeps/i386/elf/start.S:122
Any help would be appreciated. At this point I believe that 40% of the problem is the library and 60% is the case setup.
Thanks in advance!
massive_turbulence likes this.
mturcios777 is offline   Reply With Quote
Old   August 1, 2013, 12:14
Marco A. Turcios
Looking at the class again, I realized I missed calls to update mesh as well. When I add those in I get the following error:
Incompatible size before mapping.  Field size: 155680 map size: 155552
    From function void MapInternalField<Type, MeshMapper, surfaceMesh>::operator()
    Field<Type>& field,
    const MeshMapper& mapper
) const
    in file lnInclude/MapFvSurfaceField.H at line 73.
FOAM aborting
#2   at fvMesh.C:0
#3  Foam::fvMesh::mapFields(Foam::mapPolyMesh const&) in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#4  Foam::fvMesh::updateMesh(Foam::mapPolyMesh const&) in "/home/gandalf/OpenFOAM/OpenFOAM-2.2.x/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#5  Foam::linearValveFvMesh::update() in "/home/gandalf/OpenFOAM/gandalf-2.2.x/platforms/linuxGccDPOpt/lib/libmyTopochangeFvMesh.so"
#7  __libc_start_main in "/lib/libc.so.6"
I've included the changes in the attached file. One thing I don't quite see what the equivalent function for setMorphTimeIndex is in v2.2.x. I would like to eliminate this as a potential error source, so any help would be great.
Last edited by mturcios777; August 1, 2013 at 12:25. Reason: Added question about setMorphTimeIndex
Old   February 11, 2014, 07:30
Martin Beeger
Ralinus is on a distinguished road
Hello!
Im trying do simulate a moving mesh with a sliding interface with pimpleDymFoam. So far your setup and case was very helpful.
So far I got my geometry defined and also got your Valve class compiled into my openfoam 2.2.1 version. Then i succeeded in running pimpleDymFoam with my case.
The actual problem i have is, that the interface ist actually not detached and attached, which leads to enourmous cell deformation.
The picture shows my mesh after 5 steps, the lower part is moving left, the upper one is at rest.
Here a solver log:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.1-57f3c3617a2d
Exec   : pimpleDyMFoam
Date   : Feb 11 2014
Time   : 13:27:17
Host   : "HEIPC85541-ubuntu"
PID    : 1777
Case   : /home/pizzard/OpenFOAM/pizzard-2.2.1/haschur/pimpleDyMFoam/cellMotionFirstTry
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh linearValveFvMesh
Selecting motion solver: velocityComponentLaplacian
Selecting motion diffusion: directional
void linearValveFvMesh::addZonesAndModifiers() : Zones and modifiers already present.  Skipping.
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading field rAU if present
No finite volume options present
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
Courant Number mean: 2.35719e-20 max: 9.31866e-18
deltaT = 2e-06
Time = 2e-06
linearValveFvMesh: detached!
Sliding interfaces decoupled
Sliding Interfaces sucessfully decoupled!
GAMG:  Solving for cellMotionUx, Initial residual = 1, Final residual = 9.91454e-09, No Iterations 321
Coupling sliding interfaces
Moving points post slider attach
Sliding interfaces coupled: 0
GAMG:  Solving for pcorr, Initial residual = 1.50744e-05, Final residual = 5.8296e-08, No Iterations 8
GAMG:  Solving for pcorr, Initial residual = 9.90667e-06, Final residual = 4.92653e-08, No Iterations 4
GAMG:  Solving for pcorr, Initial residual = 3.34591e-06, Final residual = 4.46853e-08, No Iterations 3
time step continuity errors : sum local = 1.5378e-22, global = 1.7368e-23, cumulative = 1.7368e-23
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.0107594, Final residual = 0.000167086, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.0945104, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.00304966, Final residual = 4.73578e-05, No Iterations 2
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00610149, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.0175591, Final residual = 0.000150969, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.00556229, Final residual = 3.78537e-05, No Iterations 5
time step continuity errors : sum local = 8.60855e-08, global = 2.5772e-08, cumulative = 2.5772e-08
GAMG:  Solving for p, Initial residual = 0.0300467, Final residual = 0.000239986, No Iterations 6
GAMG:  Solving for p, Initial residual = 0.0241693, Final residual = 0.000186804, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00680939, Final residual = 5.70799e-05, No Iterations 4
time step continuity errors : sum local = 5.68957e-08, global = -1.38687e-08, cumulative = 1.19033e-08
GAMG:  Solving for p, Initial residual = 0.0250689, Final residual = 0.000146277, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00795179, Final residual = 6.37941e-05, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.0032912, Final residual = 3.15121e-05, No Iterations 4
time step continuity errors : sum local = 2.83412e-08, global = 2.01249e-08, cumulative = 3.20282e-08
GAMG:  Solving for p, Initial residual = 0.00836049, Final residual = 4.95432e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00224231, Final residual = 1.21857e-05, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.000868547, Final residual = 5.3291e-06, No Iterations 3
time step continuity errors : sum local = 4.6474e-09, global = -6.49243e-10, cumulative = 3.1379e-08
GAMG:  Solving for p, Initial residual = 0.00334386, Final residual = 2.45829e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000802673, Final residual = 5.40721e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.000319812, Final residual = 2.14775e-06, No Iterations 3
time step continuity errors : sum local = 1.87786e-09, global = 3.85007e-10, cumulative = 3.1764e-08
PIMPLE: iteration 2
DILUPBiCG:  Solving for Ux, Initial residual = 0.26793, Final residual = 3.48295e-08, No Iterations 8
DILUPBiCG:  Solving for Uy, Initial residual = 0.140926, Final residual = 1.70975e-08, No Iterations 8
DILUPBiCG:  Solving for Uz, Initial residual = 0.390905, Final residual = 4.5078e-08, No Iterations 8
GAMG:  Solving for p, Initial residual = 0.155118, Final residual = 0.00104918, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.0158902, Final residual = 0.000133865, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00473208, Final residual = 2.87043e-05, No Iterations 4
time step continuity errors : sum local = 2.69914e-08, global = 1.26524e-08, cumulative = 4.44164e-08
GAMG:  Solving for p, Initial residual = 0.0940748, Final residual = 0.00086161, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.0217233, Final residual = 0.000166681, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00587747, Final residual = 3.12268e-05, No Iterations 4
time step continuity errors : sum local = 1.56548e-08, global = -7.91986e-09, cumulative = 3.64965e-08
GAMG:  Solving for p, Initial residual = 0.0300275, Final residual = 0.000122957, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.00550682, Final residual = 3.29272e-05, No Iterations 5
GAMG:  Solving for p, Initial residual = 0.00201069, Final residual = 1.80117e-05, No Iterations 3
time step continuity errors : sum local = 8.98568e-09, global = -7.76606e-10, cumulative = 3.57199e-08
GAMG:  Solving for p, Initial residual = 0.00832041, Final residual = 7.13671e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.00163519, Final residual = 5.93839e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.000627401, Final residual = 2.99847e-06, No Iterations 4
time step continuity errors : sum local = 1.51558e-09, global = -3.25407e-10, cumulative = 3.53945e-08
GAMG:  Solving for p, Initial residual = 0.00338704, Final residual = 2.54999e-05, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000560385, Final residual = 5.51933e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.000209328, Final residual = 8.23839e-08, No Iterations 8
time step continuity errors : sum local = 4.17036e-11, global = 1.08622e-11, cumulative = 3.54054e-08
ExecutionTime = 6.47 s  ClockTime = 6 s
I have 2 questions: in your control dict, you include libs ("libmyTopochangeFvMesh.so"); What is this and where do I get it from? Do i need it?
So far I dont include this.
What i want is that the solver splits up the cells at that interface and does a new faces merging in every step. How do I tell this in the dynamic mesh dict?
If i try to run run your case i get the follwing error:
Exec   : moveDynamicMesh
Date   : Feb 11 2014
Time   : 14:14:25
PID    : 2824
Case   : /home/pizzard/Arbeitsfläche/slideTest
nProcs : 1
Create time
Unknown dynamicFvMesh type linearValveFvMesh
Valid dynamicFvMesh types are :
6
dynamicInkJetFvMesh
dynamicMotionSolverFvMesh
dynamicRefineFvMesh
multiSolidBodyMotionFvMesh
solidBodyMotionFvMesh
staticFvMesh
    From function dynamicFvMesh::New(const IOobject&)
    in file dynamicFvMesh/dynamicFvMeshNew.C at line 81.
FOAM exiting
If i use moveMesh instead everything works.
And i also get a warning that libmyTopochangeFvMesh.so could not be found.
Last edited by Ralinus; February 11, 2014 at 08:13. Reason: added infos from slide_walls
Ralinus is offline   Reply With Quote
Old   February 11, 2014, 11:58
Marco A. Turcios
Hello there!
The reason that I have the extra library specified in the controlDict is that I try to keep the base OpenFOAM code separated from anything I create, so I usually have a separate dynamically linked library that has the classes I create. Since your pimpleDyMFoam run shows that the linearValveFvMesh you have the mesh class compiled, but I wasn't able to get it running completely correctly, which is why I posted it here to work on collaboratively.
As for why you get the error message for moveDynamicMesh, it looks like the linearValveFvMesh class can't be found. When you compiled the class, did you make it part of the topoChangerFvMesh library, the dynamicFvMesh library, or was it a separate library. And is the picture included from the pimpleDyMFoam simulation?
Old   February 12, 2014, 05:37
Martin Beeger
Is used a git branch and directly replaced the files in the openfoam source code then.
The library has been built successfully afterwards.
I replaced just the src/topoChagerFvMesh/linearValveFvMesh files with your versions and changed the file under Make/files there and removed the comments for this file.
Before all 3 of them, moveMesh, moveDynamicMesh and pimpleDyMFoam gave me the above describle linearValve... not found error. After compiling the new topoChangerFvMesh.so moveMesh and pimpleDyMFoam now no longer have this Problem, but moveDynamicMesh still has.
Perhaps I need to recompile the MotionSolver lib too, I'll try that. /edit: did that too, did not help
Yes the picture below is the result of my simulation with pimpleDyMFoam, but actually the mesh is not detatched and reattached.
Thanks in advance, Martin
/edit: I ran your case with pimpleDymFoam and get a similar error to yours. Opposed to moveDynamicMesh linearValeFvMesh is known to the solver.
How to work with constant pressure? Martin Siemens 2 February 25, 2009 13:23
Getting FoamX to work shaun OpenFOAM Installation 12 March 23, 2007 08:55
work related to brake study of a vehical aero Siemens 3 November 23, 2006 07:43
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
