Viewing 2D slice of a 3D model
Old   March 14, 2014, 11:20
Default Viewing 2D slice of a 3D model
Günther Neumair
yodakohl is on a distinguished road
Hello Foamers.
I am simulating pressure and velocity of a 3D STL model. I used snappyHexMesh to
import the STL model. The simulation is done using sonicFoam. Everything works fine
but only datapoints on the surfaces are visible. I can use the slice filter in paraFoam to
visualize a 2d plane of the model, but again only datapoints on the surface are visible.
What I need to do is capture data in the empty volume between the surfaces like in this simulation: http://www.youtube.com/watch?feature...1iPyXqiWI#t=48
Here are the 3D and 2D images of the model.
I am thankful for any hints how this can be achieved.
yodakohl is offline   Reply With Quote
Old   March 14, 2014, 11:51
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
I am not quite sure what you mean, only data points on the surface are visible? If you select the slice filter, and change the field you are viewing to pressure, what do you see? Please upload a screenshot if possible.
mturcios777 is offline   Reply With Quote
Old   March 14, 2014, 13:00
Günther Neumair
I uploaded a video of pressure over time http://youtu.be/lxcW3_QNSYw .
The first picture actually shows a screenshot of the pressure. Should it be possible
to inspect the pressure and temperature of points which don't lie on the mesh out of the box?
Maybe I'm also using a to short simulation time or resolution, so pressure differences
only occure on edges. I'm going to run a more detailed and longer simulation tonight and hope for the best
Old   March 14, 2014, 13:31
Marco A. Turcios
Its hard to tell from the video, but it seems like pressure gradients are very close to the boundary. You may need to the rescale the color legend.
Old   March 15, 2014, 13:12
Günther Neumair
Thanks for your help. The problem was that my simulation time was too short. Now everything works fine
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 04:43
Mixture model + VOF? blacksoil2012 Fluent Multiphase 2 February 8, 2014 23:59
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
