A Physical Anomaly in tutorials/interFoam/laminar/damBreak |
March 21, 2014, 23:13 |
xuhe-openfoam
Rep Power: 12 |
Hello , everyone !
I found a Physical Anomaly in tutorials/interFoam/laminar/damBreak case ! I didn't modification any other thing except for the regions in setFieldsDict ! That is : regions ( boxToCell { box (0 0 -1) (1.1461 0.292 1); fieldValues ( volScalarFieldValue alpha1 1 ); This just fill up the tank about halfway with water. Then began to compute. Certenly, it is in a condition of rest ! So the Pressure and Velocity should be arround zero . But I found the wave amplitude of Pressure and Velocity is bigger and bigger in the course of time! Though the amplitude of Pressure and Velocity is still very small, it becomes bigger when there is no energy input ! I think it is a wrong numerical result! could you help me ? How to solve this problem! thanks! |
nonconservation of energy |
[Gmsh] Version 20 of the bmshb file format to FOAM converter | 7islands | OpenFOAM Meshing & Mesh Conversion | 36 | February 9, 2019 22:47 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Partition does not start on physical sector boundary!!?? | immortality | Lounge | 1 | December 8, 2013 15:04 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
