icoUncoupledKinematicParcelFoam stick particles
Old   April 23, 2014, 08:37
Default icoUncoupledKinematicParcelFoam stick particles
Giulio
LaSerpe is on a distinguished road
Hi everybody,
I'm using icoUncoupledKinematicParcelFoam to compute water droplets impingement above planes.
My problem is that the output file named "position", which as far as I know tells you the label of the cell where the particle hit the wall, says that the droplet is in a cell which doesn't have a face that belongs to a wall.
In other word many droplets hit the wall but they're not in a cell near it.
How is it possible?
I tried to change mesh and change the integration time step in the controldict dictionary but nothing worth it.
CheckMesh anyway is OK, if I run with -allGeometry Face Tets is OK but I get 1 fail due to small determinant.
the geometry is an half-wing in a test tunnel and the solver is running with a stick condition for the particles
Giulio
LaSerpe is offline   Reply With Quote
Old   April 30, 2014, 04:35
Giulio
Maybe someone knows how "stick" condition is verified by the solver?
I always though that a "stick" particle is an element which hit a wall, but could it mean that the particle is trapped in a cell, with no possibility of escaping from there?
(maybe a cell with velocity magnitude equal to 0, in which the particles gets into with a very low speed)
In this latter case the solution of my problem could be found by looking at the wall function I'm using.
I searched on many threads but I couldn't find an answer for this.
Giulio
forced to stick of soot particles kmgraju CFX 9 April 12, 2017 03:38
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
Particles don't stick to the wall with stick BC preichl OpenFOAM 2 December 13, 2010 09:06
How can i get my particles to stick? zmaxcomputer ANSYS 15 September 7, 2010 07:02
Stick criteria for particles Xubin FLUENT 0 January 11, 2002 09:29
