May 19, 2014, 06:32 |
U field missing in the output file
Rep Power: 12 |
hello everybody!
I am running an interFoam case and I realize that in the log file I don't have the values of U. The example of a time step is given below: Courant Number mean: 0.0308112 max: 0.577916 Interface Courant Number mean: 0.00290818 max: 0.455244 deltaT = 0.00239286 Time = 0.0162499 MULES: Solving for alpha1 Phase-1 volume fraction = 0.506127 Min(alpha1) = -3.7238e-39 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.506358 Min(alpha1) = -1.08909e-31 Max(alpha1) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.00222856, Final residual = 0.000102936, No Iterations 3 time step continuity errors : sum local = 0.000328819, global = -3.13238e-05, cumulative = -0.000744183 DICPCG: Solving for p_rgh, Initial residual = 0.000265302, Final residual = 9.37021e-06, No Iterations 9 time step continuity errors : sum local = 3.01083e-05, global = -7.00703e-06, cumulative = -0.00075119 DICPCG: Solving for p_rgh, Initial residual = 3.68985e-05, Final residual = 8.97875e-08, No Iterations 28 time step continuity errors : sum local = 2.86783e-07, global = -1.28258e-07, cumulative = -0.000751318 ExecutionTime = 0.74 s ClockTime = 0 s Does anyone know why it does not appear? in every timestep file, I have the U file so OpenFoam calculates it but I would be able to see and plot residuals also. I thank you very much for your answer |
May 19, 2014, 08:21 |
Do you have Code:
PIMPLE { ... momentumPredictor yes; ... } If you take a look at UEqn.H: Code:
... if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( fvc::interpolate(interface.sigmaK())*fvc::snGrad(alpha1) - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) ) * mesh.magSf() ) ); } |
May 19, 2014, 10:16 |
Rep Power: 12 |
Hi!
thank you very much!! Indeed, the problem was I had put "no" in the "momentumPredictor". As I am quite new with OpenFoam I have yet the good reflexes. :$ So I am very grateful for your answer, now I can see both p and U |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
