January 21, 2009, 10:44 |
Hello
i am new to OpenFoam an
Praveen
Rep Power: 17 |
Hello
i am new to OpenFoam and learning about two phase Euler foam solver. In the kineticTheoryModel.C, equation and page numbers are specified. Does anyone know which literature it is referred? Also it would be of great if names of some literature of Two-pahse Eulerian simulations are provided. Thanks in advance |
January 22, 2009, 00:33 |
Hi Praveen,
the reference i
Alberto Passalacqua
Rep Power: 36 |
Hi Praveen,
the reference is Berend Van Wachem Ph.D. thesis. Regards, A.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
January 22, 2009, 00:41 |
About two-fluid methodology, y
Alberto Passalacqua
Rep Power: 36 |
About two-fluid methodology, you might want to read:
H. Enwald, E. Peirano, and A. E. Almstedt. Eulerian two-phase flow theory applied to fluidization. International Journal of Multiphase Flow, 22:21 – 66, 1996. E. Peirano and B. Leckner. Fundamentals of turbulent gas-solid flows applied to circulating fluidized bed combustion. Prog. Energy Combust. Sci., 24:259 – 296, 1998. D. P. Hill. The computer simulation of dispersed two-phase flow. PhD thesis, Imperial College of Science, Technology and Medicine, London, U.K., 1998. (See www.foamcfd.org to get the PDF). In the first paper you find the references to quite a bit of useful and interesting papers. Regards, A.
January 22, 2009, 08:05 |
Thanks a lot for the informati
Praveen
Rep Power: 17 |
Thanks a lot for the information
January 30, 2009, 11:24 |
Could anyone tell me the role
Praveen
Rep Power: 17 |
Could anyone tell me the role of ppProperties and filterProperties files in the twoPhaseEulerFoam solver.
July 23, 2014, 12:13 |
twoPhaseEulerFoam
sd
Rep Power: 12 |
anybody can tell about this following error-
FOAM FATAL IO ERROR: size 6000 is not equal to the given value of 19764 file: /home/sayeed/OpenFOAM/sayeed-2.3.0/run/fluidisedBed/0/alpha.particles from line 18 to line 6047. When Im giving my own mesh file. It shows the above error. Where 6000 comes from (alpha.particles ) and 19764 from (cell/faces ) I never found this problem with other solvers!!!! little bit hints expectedly appreciate !!! |
July 23, 2014, 17:40 |
Wouter van der Meer
Rep Power: 17 |
Hello OvGU,
I have seen this error a lot of times. It happens when you use files in the 0 directory with nonuniform values (an array of values that fit the mesh) and you use another mesh with a different number of cells. For example you have used setFields to change the alphas and you change your mesh(size). That is why there often is a 0.org or alpha.org. My solution is to delete the 'non' and set a value. then delete all the values in the array up to the next boundary until I only have a file with uniform values. hope this helps Wouter |
July 24, 2014, 11:47 |
#8 | |
sd
Rep Power: 12 |
Hi Wouter many many thanks for your quick reply. Anyway it really works but my question is when Im deleting the arrays then how I can get void fraction range in post processing.I set uniform value 1/2/10 but is it really worthy? If you get some time please check once 0 folder I attached here .I am still confused about the BC though I already customized according to my geometry. |
July 24, 2014, 17:51 |
#9 |
Wouter van der Meer
Rep Power: 17 |
hello OvGU,
The setting of the boundary is only in the 0 directory. After the calculation you must not delete the array because that is what is calculated. Where is allboundary in boundaries comming from? Delete this and than use setfields or funkysetfields to set the internal fields. An internal field of alpha.air with a value of 10 seems wrong. I think it must be between 0 and 1. I do not know what solver you use, and cannot help you with this. |
Two phase flow - Euler in Fluent | MartinP | Main CFD Forum | 1 | November 3, 2006 14:15 |
Two phase flow - Euler in Fluent | MartinP | FLUENT | 0 | November 3, 2006 10:07 |
Two phase flow bubble foam | michael | OpenFOAM Running, Solving & CFD | 1 | August 23, 2006 17:06 |
Two phase flow bubble foam | michael | OpenFOAM | 1 | August 21, 2006 09:16 |
Stratified and intermittent two-phase flows : VOF vs Euler/Euler | Denis Vedrine | FLUENT | 1 | June 28, 2000 12:14 |
