September 24, 2014, 03:45 |
No Vortex Street
Philipp
Rep Power: 26 |
Hi all,
I am currently trying to get a vortex street inside a pipe but pisoFoam converges to steady state no matter what I set in fvSchemes. I resolve the boundary layer and don't see the street for the k-omega-SST and the Launder-Sharma-k-epsilon model. This is what exactly the same grid produces in Fluent (with standard settings) vortex_street.jpg The question is, why does it work in Fluent and not in OpenFoam? If you need more info, just tell me what to post! Thanks, Philipp.
The skeleton ran out of shampoo in the shower. |
September 24, 2014, 06:52 |
Rep Power: 12 |
You have to set up a disturbance, guess your mesh is fully structured?
Add some acoustic noise or time dependent velocity dist. or create a small assymetry of your Mesh. See here around second 10! http://www.youtube.com/watch?v=hsmT0zvKNeM |
September 24, 2014, 07:33 |
Philipp
Rep Power: 26 |
Ok, how can I do that?
I got a velocity inlet with U, k and omega/epsilon profiles from a first simulation at the inlet
September 25, 2014, 04:48 |
Philipp
Rep Power: 26 |
Also, I don't think that OpenFoam can handle structured grids. If you mean that my grid is created in ICEM using blocking / hexa, then I can answer "yes". But it is converted to unstructured grid when using it in OpenFoam.
August 15, 2015, 11:36 |
Davi Barreira
Rep Power: 12 |
Did you figure out a way to get the vortex street? Im having the same problem.
August 16, 2015, 15:50 |
Philipp
Rep Power: 26 |
Yes, if I recall correctly, I had much too high residuals. So I actually didnt solve the equations... Can you post your log file? How many time steps per (expected) vortex cycle do you have?
In my case I had to reduce the time step strongly or increase the number of pressure corrections to get lower continuity residuals.
August 16, 2015, 17:23 |
Davi Barreira
Rep Power: 12 |
I figured what was wrong. The problem was the turbulence model. I was using k-epsilon and they were smearing the vortices. I ran a simulation with Re = 150 with laminar flow, and the vortex street showed up. The only thing Im trying to solve now is the values of Drag and Lift Coefficient, that Im getting above the expected.
Thanks for the reply, anyways! |
August 17, 2015, 06:38 |
Philipp
Rep Power: 26 |
OK... But it should work with k-epsilon as well. If you still want to get it running, just let us know.
August 17, 2015, 18:35 |
#9 |
Davi Barreira
Rep Power: 12 |
Really? I read people saying that k-epsilon would dissipate the vortices... So what do you think would be the problem?
Actually, right now Im more worried about the Drag Coefficient. I keep on getting a 1.44 (converging with mesh improvements), but I should be getting something closer to 1.33 (in another paper, the author got a 1.38 with OpenFOAM). My flow is a laminar flow with 150 Re ... Any ideas? Cheers |
September 3, 2015, 22:48 |
#10 |
Davi Barreira
Rep Power: 12 |
RodriguezFatz,
I manage to get the laminar flow to produce great results... now Im trying it out with higher Reynolds number with k-epsilon (also playing with some LES)... k-epsilon is giving reasonable values of drag coefficient, but no vortex-street. Would you now how to set it up? Regards |
September 4, 2015, 01:49 |
#11 |
Philipp
Rep Power: 26 |
Ok, so can you post some log output of the k-epsilon case that doesn't work?
And the schemes file.
September 4, 2015, 06:22 |
#12 |
Davi Barreira
Rep Power: 12 |
I increased the mesh refinement and let it run for a long time. After an appreciable time (the flow looked like it was stationary already) the vortices started to form.
Sorry for bothering you, I should've tried longer before asking in the forum. But thank you very much for the reply, I really appreciate it. Anyways, here are my fvScheme and fvSolution, if you have any tips on how to improve the simulation. regards |
September 4, 2015, 07:01 |
#13 |
Philipp
Rep Power: 26 |
Do you have the log as well?
September 4, 2015, 07:29 |
#14 |
Rep Power: 12 |
Just an additional information regarding my mesh post,
Of course OF can handle structured or unstructured meshes, what I wanted to say is, if your mesh is fully structured it is a 100% symmetrical mesh with respect to cylinder`s center axis in flow direction. The flow always follows your mesh, so it keeps symmetrical a very long time. For decreasing this waiting time, some people tend to create a small mesh disturbance on on side of the symmetry side. So you get a small disturbance - produced by small mesh assymmetry - which equals in assymmetric flow and vortex shedding.... |
September 4, 2015, 07:36 |
#15 |
Philipp
Rep Power: 26 |
hxaxtam, I think OF does not handle structured meshes, just unstructured. Also, structured does not mean that a mesh is symmetrcal to anything. Are you sure you use the correct words?
September 4, 2015, 08:15 |
#16 | |
Rep Power: 12 |
OF handles structured and or unstructured meshes by solving the NS in an unstructured way. This is what I meant.... Regarding the test case of davibarreira: Discretization: C-H-O Mesh Type (structured) -> Axis symmetry! Of course not in general! |
September 4, 2015, 08:24 |
#17 |
Philipp
Rep Power: 26 |
I don't understand you...
Structured and unstructured is just a matter of how the software internally stores the mesh and this is unstructured for Openfoam (as for Fluent and I guess most other solvers). You can not use a structured mesh in OpenFoam. Maybe you can import structured meshes by converting them to unstructured, but I don't know about that. Where can I see davibarreiras mesh?
September 4, 2015, 08:37 |
#18 | |
Rep Power: 12 |
September 5, 2015, 09:16 |
#19 |
Davi Barreira
Rep Power: 12 |
Sorry, I dont have a log.
I think hxaxtma meant a mesh with all orthogonal cells (all the cells are cubes, therefore, the mesh could be completely symmetric). |
September 8, 2015, 02:44 |
#20 |
Philipp
Rep Power: 26 |
Davi, without the log I can't help, because that's where the mistakes show up usually...
Karman Vortex street | Apocolapse | STAR-CCM+ | 2 | December 12, 2011 10:53 |
Vortex Street with pisoFoam | mikahs | OpenFOAM Running, Solving & CFD | 0 | June 10, 2011 09:00 |
karman vortex street help please | SSeth | STAR-CCM+ | 7 | January 10, 2011 11:31 |
Vortex Street | Blunderbus | Main CFD Forum | 6 | February 24, 2009 18:47 |
Kármán vortex street in cavitating flow behind bodies in the cavitation tunnel | L. Könözsy | Main CFD Forum | 0 | April 17, 2000 13:16 |
