[swak4Foam] How to even start swak4foam cases |
November 5, 2017, 09:26 |
Rep Power: 8 |
I just set up my first simulation with Openfoam 1706+ docker image and imported geometries from Salome. Works so far. Next I would like to run swak4foam examples to try groovybc. I installed the docker container and copied pulsedpitzdaily to my home folder. The tutorial says the next step would be to run blochMesh, which works. I had a look into the system folder and this example seems to use pisoFoam so I started pisoFoam which leads to an error message about a missing turbulenceProperties file. As there is a turbulenceProperties.template file I guess pisoFoam is the wrong command. I could not find a source on how to use swak4foam that describes the command I need to use. Any ideas? kinder regards, Mabubel |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
simpleFoam crushes at 1st Time loop. | seav | OpenFOAM Running, Solving & CFD | 18 | June 4, 2013 08:18 |
Is OpenFOAM tutorial cases valid? | j-avdeev | OpenFOAM Running, Solving & CFD | 3 | September 19, 2012 15:45 |
on the definition of Start in shell autoignition | mepgzzi | Siemens | 0 | June 18, 2008 10:33 |
Lets start the public domain CFD-Project! | Heinz Wilkening | Main CFD Forum | 3 | March 11, 1999 22:55 |
