[swak4Foam] How to even start swak4foam cases |
November 5, 2017, 09:26 |
Rep Power: 9 |
I just set up my first simulation with Openfoam 1706+ docker image and imported geometries from Salome. Works so far. Next I would like to run swak4foam examples to try groovybc. I installed the docker container and copied pulsedpitzdaily to my home folder. The tutorial says the next step would be to run blochMesh, which works. I had a look into the system folder and this example seems to use pisoFoam so I started pisoFoam which leads to an error message about a missing turbulenceProperties file. As there is a turbulenceProperties.template file I guess pisoFoam is the wrong command. I could not find a source on how to use swak4foam that describes the command I need to use. Any ideas? kinder regards, Mabubel |
November 5, 2017, 12:17 |
Rep Power: 9 |
the next thing I tried (found it here: http://openfoamwiki.net/index.php/Contrib/PyFoam) was pyfoamrunner.py:
[me@799b435714a2 pulsedPitzDaily]$ pyFoamRunner.py pisoFoam Reading regular expressions from /home/me/OpenFOAM/pulsedPitzDaily/customRegexp PyFoam WARNING on line 42 of file /usr/lib/python2.7/site-packages/PyFoam/Infrastructure/ServerBase.py : No certficate file /home/me/.pyFoam/foamServerCertificate.cert exists. Therefor no SSL-connection for the FoamServer possible To generate a private key: openssl genrsa -out /home/me/.pyFoam/foamServerCertificate.key 2048 Then generate the cerificate that is valid for 3 years with openssl req -new -x509 -key /home/me/.pyFoam/foamServerCertificate.key -out /home/me/.pyFoam/foamServerCertificate.cert -days 1095 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706 Arch : "LSB;label=32;scalar=64" Exec : pisoFoam Date : Nov 05 2017 Time : 14:34:57 Host : "799b435714a2" PID : 355 Case : /home/me/OpenFOAM/pulsedPitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1321 dlopen error : libswakPythonIntegration.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 101 could not load "libswakPythonIntegration.so" profiling initialized Create mesh for time = 0 PISO: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian --> FOAM FATAL IO ERROR: cannot find file file: /home/me/OpenFOAM/pulsedPitzDaily/constant/turbulenceProperties at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 237. FOAM exiting |
January 31, 2022, 19:13 |
Sung Kwon
Rep Power: 5 |
I am having a same problem Did you figure out how to do it? Thanks in advance. |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
simpleFoam crushes at 1st Time loop. | seav | OpenFOAM Running, Solving & CFD | 18 | June 4, 2013 08:18 |
Is OpenFOAM tutorial cases valid? | j-avdeev | OpenFOAM Running, Solving & CFD | 3 | September 19, 2012 15:45 |
on the definition of Start in shell autoignition | mepgzzi | Siemens | 0 | June 18, 2008 10:33 |
Lets start the public domain CFD-Project! | Heinz Wilkening | Main CFD Forum | 3 | March 11, 1999 22:55 |
