FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file |
October 27, 2009, 09:43 |
Hi all!
I have following problem while running OpenFOAM 1.6 on cluster with queuing system. I compiled OpenFOAM from scratch using GCC from OF distribution and MVAPICH installed on cluster. OpenFOAM runs perfect on login machine in serial, but when I start it with queuing system it fails with such error in error output: --> FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file 'controlDict' As I understand, OpenFOAM could not get proper environment variable while running on remote machine. How to provide proper environment for OpenFOAM? Thank you in advance
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
October 27, 2009, 12:03 |
Problem solved!
Tommorow read about my expereance with OpenFOAM on MVAPICH+InfinityBand
September 3, 2011, 04:48 |
mrv4real
Rep Power: 14 |
even if this is an very old thread, do you remember the solution? Do i have to set some environment variables and if yes, which are they? setting the -case unfortunately did not work. Thanks in advance, mrv4real |
September 3, 2011, 07:39 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings mrv4real and welcome to the forum!
There are at least two ways for doing this:
Bruno
September 3, 2011, 08:19 |
mrv4real
Rep Power: 14 |
Hi Bruno,
thanks a lot for the nice welcome message and your fast reply! I tried your suggestions but am still having problems. I try to run it on a BlueGene/P and it works for serial code. If I try it with mpirun in a loadleveler script, i had to pass the LD_LIBRARY_PATH environment variable and allthough that i specify the case directory with "-case <...>" he throws the error message about the missing controlDict. Is there a way to give the directory of the simulation using an environment variable i can pass to the mpirun? Thanks, mrv4real |
September 3, 2011, 08:33 |
mrv4real
Rep Power: 14 |
... maybe it is best, if I post the script for the loadleveler. Hoping for some sugesstions...
#!/bin/sh # @ account_no = [] # @ job_name = test_damBreak # @ output = $(job_name).out # @ error = $(job_name).err # @ environment = COPY_ALL # @ wall_clock_limit = 00:05:00 # @ notification = always # @ notify_user = my@address.net # @ job_type = bluegene # @ bg_size = 4 # @ queue source ~/OpenFOAM/OpenFOAM-1.6/etc/bashrc cd /home/my_account/damBreak mpirun -np 4 -mode SMP -cwd /home/my_account/damBreak -exe /home/my_account/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/interFoam -args "-case /home/my_account/damBreak -parallel" -env LD_LIBRARY_PATH=/home/my_account/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/mpi:/home/my_account/OpenFOAM/my_account-1.6/lib/linuxGccDPOpt:/home/my_account/OpenFOAM/site/1.6/lib/linuxGccDPOpt:/home/my_account/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt Thanks a lot, mrv4real |
September 3, 2011, 09:43 |
Bruno Santos
Rep Power: 128 |
Hi mrv4real,
I forgot to mention that the controlDict that the solver is complaining about is not the one in your case's system folder; it is complaining about not finding "OpenFOAM-1.6/etc/controlDict". This means that LD_LIBRARY_PATH is far from enough; there are a whole lot more variables that would need exporting. Mmm... OpenFOAM 1.6 is getting old now... but OK, let's try this:
Bruno
September 3, 2011, 10:05 |
mrv4real
Rep Power: 14 |
i already tried it with a script, but then mpirun gives the error "Load failed on 172.16.100.69: Magic value in ELF header of executable file is invalid" This comes from the fact, that foamExec is a script and not an executable. I found something about a "-m script" switch for mpirun, but the BlueGene doesn´t accept it... Thanks, mrv4real |
September 3, 2011, 11:27 |
#9 |
Bruno Santos
Rep Power: 128 |
I did a bit of googling and found this: http://bluegene.epfl.ch/mpirun.txt
There seems to be an option named "-env_all". This would simplify the script, therefore not needing foamExec nor to manually define each variable to be sent. If that doesn't work, then it's not going to be pretty If I'm not mistaken, the necessary variables are: PATH LD_LIBRARY_PATH WM_PROJECT_DIR WM_PROJECT_INST_DIR WM_OPTIONS FOAM_LIBBIN FOAM_APPBIN FOAM_USER_APPBIN MPI_BUFFER_SIZE The last one depends on the MPI you are using in BlueGene. In bold are the ones that are reeeeally necessary. I think the other ones are sometimes necessary... Something like this should work: Code:
#!/bin/sh # @ account_no = [] # @ job_name = test_damBreak # @ output = $(job_name).out # @ error = $(job_name).err # @ environment = COPY_ALL # @ wall_clock_limit = 00:05:00 # @ notification = always # @ notify_user = my@address.net # @ job_type = bluegene # @ bg_size = 4 # @ queue source ~/OpenFOAM/OpenFOAM-1.6/etc/bashrc cd /home/my_account/damBreak mpirun -np 4 -mode SMP -cwd $PWD -exe `which interFoam` -args "-parallel" -exp_env LD_LIBRARY_PATH -exp_env PATH -exp_env WM_PROJECT_DIR -exp_env WM_PROJECT_INST_DIR -exp_env WM_OPTIONS -exp_env FOAM_LIBBIN -exp_env FOAM_APPBIN -exp_env FOAM_USER_APPBIN -exp_env MPI_BUFFER_SIZE Oh, about PWD: this is usually an environment variable that has the path for the current directory, but it might not work on the environment you are working on Best regards, Bruno
September 3, 2011, 14:34 |
#10 |
mrv4real
Rep Power: 14 |
thanks a lot !!! now it works.
Best, mrv4real |
December 2, 2011, 09:29 |
#11 |
Rep Power: 15 |
Edit: sorry for posting.
April 4, 2014, 21:34 |
problem in running openfoam in parallel
#12 |
Vishal Nandigana
Rep Power: 18 |
Hello Foamers,
I was able to compile my test code (PNPFoam) and could run it in a serial mode in Kraken cluster. However, when I was trying to run a parallel case, I had an error similar to the ones discussed in the above message. Code:
FOAM FATAL ERROR in Foam::findEtcFiles() : could not find mandatory file 'controlDict--> FOAM FATAL ERROR in Foam::findEtcFiles() : could not find mandatory file Below is my sample script file to run the parallel case. Code:
#!/bin/bash #PBS -A TG-CDA100010 #PBS -l size=72,walltime=00:02:00 #PBS -o a.out #PBS -N simout cd $PBS_O_WORKDIR aprun -n 72 -N 12 /lustre/scratch/joonho/openfoamv/conc_10mM/2D_simulations/PNP_solve/PNP_Foam Code:
export LD_LIBRARY_PATH=/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/system-dynlib:/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/mpich2-system:/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/dummy:/opt/gcc/mpc/0.8.1/lib:/opt/gcc/mpfr/2.4.2/lib:/opt/gcc/gmp/4.3.2/lib:/opt/gcc/4.6.2/snos/lib64:/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib:/opt/cray/atp/1.4.1/lib export PATH=/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/wmake:/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin:/lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/bin:/opt/cray/atp/1.4.1/bin:/opt/cray/xt-asyncpe/5.11/bin:/opt/cray/pmi/2.1.4-1.0000.8596.15.1.ss/bin:/opt/gcc/4.6.2/bin:/nics/e/sw/xt-cle3.1/xdusage:/sw/xt/globus/5.0.4/binary/bin:/sw/xt/globus/5.0.4/binary/sbin:/sw/altd/bin:/usr/local/hsi/bin:/usr/local/gold/bin:/sw/xt/bin:/opt/moab/6.1.6/bin:/opt/torque/2.5.11/bin:/opt/cray/lustre-cray_ss_s/1.8.4_2.6.27.48_0.12.1_1.0301.5943.18.1-1.0301.27524.1.24/sbin:/opt/cray/lustre-cray_ss_s/1.8.4_2.6.27.48_0.12.1_1.0301.5943.18.1-1.0301.27524.1.24/bin:/opt/cray/MySQL/5.0.64-1.0301.2899.20.1.ss/sbin:/opt/cray/MySQL/5.0.64-1.0301.2899.20.1.ss/bin:/opt/cray/sdb/1.0-1.0301.25929.4.88.ss/bin:/opt/cray/nodestat/2.2-1.0301.25918.4.1.ss/bin:/opt/modules/3.2.6.6/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/opt/cray/bin Thanks Regards, Vishal Last edited by wyldckat; April 6, 2014 at 13:48. Reason: Added [CODE][/CODE] |
April 6, 2014, 13:46 |
#13 |
Bruno Santos
Rep Power: 128 |
Greetings Vishal,
You should contact the administrator for the cluster you're using and/or read the instructions on their website. Because it seems that you're using a dedicated installation of OpenFOAM 2.1.1, which very likely will not work how we might expect, since we don't have access to the cluster you're using. Because from your description, you seem to be confusing the path to your case "/lustre/scratch/joonho/openfoamv/conc_10mM/2D_simulations/PNP_solve/PNP_Foam" with the path to your application "PNPFoam". My guess is that you should change your script to something like this: Code:
#!/bin/bash #PBS -A TG-CDA100010 #PBS -l size=72,walltime=00:02:00 #PBS -o a.out #PBS -N simout cd $PBS_O_WORKDIR . /lustre/scratch/proj/sw/openfoam/2.1.1/cnl3.1_gnu4.6.2/OpenFOAM-2.1.1/etc/bashrc aprun -n 72 -N 12 /full/path/to/your/PNPFoam -case /lustre/scratch/joonho/openfoamv/conc_10mM/2D_simulations/PNP_solve/PNP_Foam -parallel Best regards, Bruno
April 21, 2015, 07:32 |
#14 | |
Sami
Rep Power: 13 |
Thanks it works !
November 18, 2015, 18:51 |
WM_PROJECT_DIR was the culprit in my case
#15 |
Thomas Oliveira
Rep Power: 12 |
I received the message "FOAM FATAL ERROR in Foam::findEtcFile() : could not find mandatory file 'controlDict'" when running splitMeshRegions from the command line, but it worked when called through a script. After comparing the environment variables in each situation and doing some test, I found out that the culprit was the variable WM_PROJECT_DIR.
Could anyone explain the relationship between the variable WM_PROJECT_DIR being wrongly set (it should points to where OpenFOAM is installed) and splitMeshRegions not finding the controlDict file (whose path is specific to the case I am working in)? Thanks, Thomas |
November 18, 2015, 19:00 |
#16 |
Thomas Oliveira
Rep Power: 12 |
After some more tests, I realised that the mandatory file 'controlDict' which was not found didn't refer to the system/controlDict file of my specific case. Instead, it referred to the $WM_PROJECT_DIR/etc/controlDict file.
Now the relationship between the variable WM_PROJECT_DIR and the error message makes sense. Regards, Thomas [EDIT: and now I noticed that wyldckat had already pointed out to this fact in September 3, 2011]. |
open_udf_library: The system cannot find the file | John | FLUENT | 6 | November 10, 2021 23:16 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
open_udf_library: The system cannot find the file | john | CFX | 1 | February 13, 2005 00:21 |
