thermal CFD simulation of CO2 in OpenFOAM
Old   January 25, 2015, 07:09
Default thermal CFD simulation of CO2 in OpenFOAM
Ivan
cfdhelp is on a distinguished road
Dear friends,
I want to ask you, if somebody can help me to find some solver in OF (maybe rhoSimpleFoam, rhoPimpleFoam, buoyantSimpleFoam ...).
I want to simulate carbon dioxide (CO2) heat transfer to stell tube.
There is one picture attachment in my question.
My testing case can be described in a few sentences and is divided in two steps:
For first steps I want to simulate only flow of CO2 with material properties for constant pressure 10MPa in tube with density, viscosity, therm. cond., heat capacity as a function of temperature. (see attached picture) I want to define this properties through linear piecewise function.
And second step is simulation with heat transfer into steel tube.
Thank you for your answers, cfdhelp.
cfdhelp is offline   Reply With Quote
Old   January 31, 2015, 10:14
Retired Super Moderator
Bruno Santos
Greetings Ivan and welcome to posting on the forum!
It's very difficult to suggest a specific solver for the first step, because it depends on whether the temperature range is big enough and if the fluid can be considered incompressible or not.
My best suggestion is that perhaps you should start off with this tutorial from the wiki: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D - it addresses mostly your second step, but it also gives indications on how to proceed before jumping directly to the final problem.
Because it seems to me that you're dealing with a lot of different issues in a single problem and you should perhaps first study how each issue will affect you. For example:
  1. Flow rate inside the pipe.
  2. Expected temperature range.
  3. If the flow is pressure driven or of imposed flow rate.
  4. 10 MPa is a very high pressure. It strongly depends on the pressure range you'll be working around this reference value.
  5. Choosing whether a steady-state ("*SimpleFoam") or transient ("*PimpleFoam") solver should be used will depend on the complexity of the flow.
In other words, you need to be able to properly define these and several other operating features, before jumping directly to the final problem
Best regards,
Bruno
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. Mahesh7238 FLUENT 1 April 5, 2021 00:21
[Commercial meshers] Converting mesh from Icem CFD to OpenFoam thyxxx OpenFOAM Meshing & Mesh Conversion 5 October 10, 2018 07:04
Is real time CFD simulation possible yedla Main CFD Forum 5 March 28, 2016 09:56
Centrifugal fan impeller CFD simulation in OpenFoam ZachJa OpenFOAM 3 December 3, 2014 10:00
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
