Sloshing Case - Probing or Sampling free surface during runtime
Old   February 17, 2015, 03:34
Default Sloshing Case - Probing or Sampling free surface during runtime
Esweer is on a distinguished road
In order to runtime post-process a sloshing case (3D) different options are available to sample the free surface in distinct locations inside the domain. I am currently using OpenFOAM 2.3.0 to do some test calculations for that.
Runtime postprocessing functions can be used in the system/controlDict for fast and easy determination of the values. First option is using the "set" function.
functions
    Probe01
    type                          sets;
    interpolationScheme     cellPoint;
    outputControl              adjustableTime;
        writeInterval           0.05;
    setFormat                  raw;
    sets
    centerPatch
        type uniform;
        axis xyz;
        start (0.000 0.000 1.000);
        end   (0.000 0.000 2.000);
        nPoints 10;
    surfaces
    fields
        alpha.water
The above works fine for interpolating the free surface from cell (interpolation Scheme can be given by switch interpolationScheme), but unfortunately the probed set is fixed in space and there seems to be no way to move the probe location with the dynamic mesh.
Second option in runtime postprocessing functions is the "probe" function, where definition of single probe locations in a line can be done e.g. like this:
functions
    Probe02
        type                       probes;
        functionObjectLibs     ("libsampling.so");
        writeInterval             0.05;
        probeLocations
           (0.000 0.000 1.000)
           (0.000 0.000 1.100)
           (0.000 0.000 1.200)
           (0.000 0.000 1.300)
           (0.000 0.000 1.400)
           (0.000 0.000 1.500)
           (0.000 0.000 1.600)
           (0.000 0.000 1.700)
           (0.000 0.000 1.800)
           (0.000 0.000 1.900)
           (0.000 0.000 2.000)
        fixedLocations  false;
        fields
            alpha.water
By setting the switch fixedLocations to true, the probe locations are again fixed in space, by setting to false the probes are moving relative to the dynamic mesh. Unfortunately, here no interpolation scheme can be user selected and the function is always using interpolation to cell, resulting in quite coarse resolution of free surface.
Therefore both ways do not seem to lead to what I am interested in, interpolating the free surface with cellPoint interpolation in locations fixed in the dynamic Mesh. Does anyone have ever thought about a solution for this problem? I guess so!
I have also tried to do the same with sampleDict or probeDict postprocessing, but obviously the switch "fixedLocations false;" is not functioning their in either case.
Looking very much forward for your kind help!
Esweer is offline   Reply With Quote
free surface modelling using VOF sci Main CFD Forum 10 August 29, 2012 07:43
sloshing free surface Jaime FLUENT 1 December 2, 2008 13:12
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Free Surface Modelling (sloshing) fakir CFX 0 November 23, 2006 02:23
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
