elasticSolidFoam - crash with non-orthogonal correction
Old   March 9, 2015, 09:47
Default elasticSolidFoam - crash with non-orthogonal correction
Aram Amouzandeh
mabinty is on a distinguished road
Dear all,
I am simulating a kind of beam fixed on top and loaded on the bottom in longitudinal direction of the beam.
The used solver is elasticSolidFoam (foam-extend 3.1) but the same behaviour is observed with elasticIncrSolidFoam. When the non-orthogonal correction is switched off, such as
 laplacianSchemes
    default         none;
    laplacian(DU,U) Gauss linear uncorrected;
snGradSchemes
    snGrad(U)       uncorrected;
the simulation converges quite fast. At the moment I switch on non-orthogonal correction ("corrected" instead of "uncorrected" for laplacian(DU,U) and snGrad(U)) the solver crashes after several hundreds of iterations with a floating point exception (log.elasticSolidFoam see attachments: Time 1 with, Time 2 without non-orthogonal correction).
The mesh was generated with snappy (checkMesh log see attachment). The average non-orthogonality seems to be OK and its correction should not introduce too much instability (at least for my experience with CFD) so I currently do not know where the real problem lies.
I also tried to play with the settings in the system/fvSolution dictionary such as with the methods for the explicit term divSigmaExp, or switching on/off the aitkenRelaxation. No improvements!
I greatly appreciate your comments!
Cheers,
Aram
mabinty is offline   Reply With Quote
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Non orthogonal correction for diffusion-like term in pressure equation eltenedor Main CFD Forum 0 February 28, 2015 16:26
Production correction or curvature correction in the SST model Ang CFX 2 May 20, 2014 20:50
Star ccm 9.02 - unsteady flux dissipation correction fivos STAR-CCM+ 4 April 28, 2014 09:37
About nonorthogonal correction in fvclaplacian 7islands OpenFOAM Running, Solving & CFD 4 December 9, 2012 22:54
