interRegionHeatTransferModel fvOptions in OpenFOAM-2.2.2 |
May 26, 2015, 08:22 |
Rohith
Rep Power: 13 |
Hi all,
I have tried to implement an additional source term in order to enhance heat transfer between two different meshes in OpenFOAM-2.2.2 using fvOptions constantHeatTransfer. The definition of the source term in the problem is done in the right way, nevertheless i have additional errors. I have tried to find the root cause, things are a bit unclear. Can some one tell me why the below error appears. i have defined the htc (heat transfer Coeff) and Aov (Area). Code:
--> FOAM Warning : From function void option::checkApplied() const in file fvOptions/fvOption.C at line 365 Source fluid1Tofluid2 defined for field cp,T but never used Any kind of hint or experience may help. Best Regards, RRK. Last edited by RaghavendraRohith; June 3, 2015 at 08:20. |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
OpenFOAM 2.2.2 | Maimouna | OpenFOAM | 1 | October 14, 2013 13:30 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
