Flow and heat transfer in porous media
Old   June 10, 2015, 10:15
Question Flow and heat transfer in porous media
tos
tos is on a distinguished road
Dear all,
is there a simple method to model flow and heat transfer in a porous media where the fluid and solid phase are not in local thermal equilibrium (T_fluid and T_solid are not equal)? Ideally it should be possible to have a nonuniform porosity.
I tried to use the chtMultiRegionFoam solver together with the constantHeatTransfer and the interRegionExplicitPorositySource option in the fvOptions file but this was not possible when using a fluid and solid region.
Thanks for your help.
tos is offline   Reply With Quote
Old   August 18, 2016, 00:28
Bibin K.S
bibin.sme is on a distinguished road
Hi Tos,
I’m trying the same. did you get any solution to this
bibin.sme is offline   Reply With Quote
Old   April 1, 2017, 14:48
alberto
dewey is on a distinguished road
Did you find a way to do that?
i am trying to modelate a pipe with fluid and porosu media obstacle. And heat transfer.
Do you knoe if exist a solver? or if i have to create one?
dewey is offline   Reply With Quote
Heat transfer under oscillating flow through porous media highhopes FLUENT 4 April 22, 2015 00:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
gas flow and heat transfer in porous media styoung317 Main CFD Forum 0 June 23, 2005 21:01
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
