no residual information for velocity in simpleFoam |
July 17, 2015, 05:36 |
Robert Castilla
Rep Power: 17 |
I have recently seen a weird behaviour of simpleFoam solver. I shows only information for p equation residuals, but not for velocity: ... Time = 8e-07 GAMG: Solving for p, Initial residual = 6.50381e-05, Final residual = 6.347283e-09, No Iterations 76 GAMG: Solving for p, Initial residual = 0.000211505, Final residual = 1.97172e-08, No Iterations 37 GAMG: Solving for p, Initial residual = 9.692022e-05, Final residual = 8.045532e-09, No Iterations 24 GAMG: Solving for p, Initial residual = 2.10692e-05, Final residual = 2.085201e-09, No Iterations 19 time step continuity errors : sum local = 4.167724e-11, global = 1.860175e-11, cumulative = 1.024744e-10 ExecutionTime = 31.94 s ClockTime = 32 s Time = 9e-07 GAMG: Solving for p, Initial residual = 5.70272e-05, Final residual = 5.510404e-09, No Iterations 74 GAMG: Solving for p, Initial residual = 0.0001498911, Final residual = 1.306778e-08, No Iterations 37 GAMG: Solving for p, Initial residual = 6.914938e-05, Final residual = 5.904203e-09, No Iterations 24 GAMG: Solving for p, Initial residual = 1.56225e-05, Final residual = 1.282677e-09, No Iterations 21 time step continuity errors : sum local = 2.563705e-11, global = 1.243251e-11, cumulative = 1.149069e-10 ExecutionTime = 38.88 s ClockTime = 39 s Time = 1e-06 .... Any information of the reason of that? Best regards Robert |
August 10, 2015, 09:43 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: "system/fvSolution", inside SIMPLE, you have "momentumPredictor" set to "no".
edit: I've added it to the FAQ: http://openfoamwiki.net/index.php/FA...y_equations.3F Last edited by wyldckat; August 10, 2015 at 09:47. Reason: see "edit:" |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
should Courant number always be kept below 1? | wc34071209 | OpenFOAM Running, Solving & CFD | 16 | March 9, 2014 19:31 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
