July 23, 2015, 17:26 |
Water heat exchange with heRhoThermo?
Benjamin Bergmann
Rep Power: 10 |
Hallo,
im using OpenFoam on this site. Simscale.com So far so good, but when I calculate heat transfere I can only choose the following model. Thermo Type: herhothermo pure mixture transport const thermo model: hconst perfectgas species model specie: My question is. Can this model be used to simulate water if all the substance constants are changed to the values of water or does a different thermo type has to be used? Tanks a lot. Best regards. Benjamin |
July 24, 2015, 10:35 |
Johannes Probst
Rep Power: 12 |
Hi Benjamin,
you can use the buoyant solver family for this kind of problems. SimScale offers buoyantSimpleFoam and buoyantPimpleFoam under the category "Natural convective heat transfer". You can optionally choose a turbulence model and select transient (buoyantPimpleFoam) or steady-state (buoyantSimpleFoam) behaviour. These solvers are well-suited for heat transfer and convection problems with buoyancy. Best regards Johannes |
July 27, 2015, 04:20 |
Benjamin Bergmann
Rep Power: 10 |
Hallo,
thank you for your answer. I usedbuoyantSimpleFoam and KOmega-SST as a turbulence model. The whole thin in stationäre form. In the Model section i hve to choose perfectGas Every other value is the value of water at 315K. What I model is the follwowing. In a pipe fo 13mm diameter I place a rod with 7mm diamtere coaxially. In the ring cavity between the two water is used as a cooling fluid. The volume flow is 11L/min. The power produced by the rod is 1200W. I expected something by analytical calculations a litle lower than 373K. Instead i get something arround 1250K. That is absalutely impossible. I think it has something to do with te ideal gas thing. Can you point me into the right direction. Thank you very much. Best regards. Benjamin |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Heat Transfer Coefficient of water | shreesha87 | CFX | 15 | December 4, 2013 06:25 |
Heat Transfer Coeff on the water air interface | Anton | Main CFD Forum | 3 | June 2, 2010 01:49 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
heat transfer: air in a room and water in a coil | Alberto | CFX | 2 | May 9, 2006 09:56 |
