icouncoupledkinematicparcelfoam error: corrupted double-linked list
Old   September 3, 2015, 10:50
Default icouncoupledkinematicparcelfoam error: corrupted double-linked list
Sören Sander
Sören Sander is on a distinguished road
I get an error when using the solver
"corrupted double-linked list"
This happens when I eighter run the solver in parallel or start the solver multiple times with different cases.
Anyone else experienced this problem or knows if it is a bug, or how to solve it?
Sören Sander is offline   Reply With Quote
Old   September 5, 2015, 12:49
Retired Super Moderator
Bruno Santos
Quick answer: That is very common to happen when custom libraries are loaded in the "libs" entry in "system/controlDict". Usually happens because the name of the custom class is identical to the original class.
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
