Is it possible to use fsiFoam in parallel?
Like Tree1Likes
  • 1 Post By Woj3x
Old   January 2, 2016, 15:24
Default Is it possible to use fsiFoam in parallel?
Wojciech Gołąbek
Woj3x is on a distinguished road
Hello
I tried to do this in base case: beamInCrossFlow but it failed.
What modification did I do in case?
I modified Allrun file like this:
#!/bin/sh
 # Source tutorial run functions
 . $WM_PROJECT_DIR/bin/tools/RunFunctions
 # Get application name
 application=`getApplication`
 runApplication -l log.blockMesh.solid blockMesh -region solid
 runApplication -l log.setSet.solid setSet -case ../solid -batch ../solid/setBatch
 runApplication -l log.setToZones.solid setsToZones -case ../solid -noFlipMap
 runApplication blockMesh
 runApplication setSet -batch setBatch
 runApplication setsToZones -noFlipMap
 runApplication decomposeParFsi
 cd ..
 ./makeLinks fluid solid
 cd fluid
 # Build hronTurekReport function object
 wmake libso ../setInletVelocity
 runParallel $application 2
 # ----------------------------------------------------------------- end-of-file
In decomposeParDict I changed:
numberOfSubdomains 2
n (2 1 1);
Then I run this case in standard way:
sed -i s/tcsh/sh/g *Links
./removeSerialLinks fluid solid
./makeSerialLinks fluid solid
cd fluid
./Allclean
./Allrun
I received the following information in log.fsiFoam:
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.1                                |
|   \\  /    A nd           | Web:         http://www.extend-project.de       |
Build    : 3.1-1dd681f6e943
Exec     : fsiFoam -parallel
Date     : Jan 02 2016
Time     : 20:55:20
Host     : FOX-MS-7816
PID      : 9059
CtrlDict : /home/wojciech/foam/foam-extend-3.1/etc/controlDict
Case     : /home/wojciech/FluidStructureInteraction/pararelTest/beamInCrossFlow/fluid
nProcs   : 2
Slaves :
1
FOX-MS-7816.9060
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : blocking
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityLaplacian
Selecting motion diffusion: quadratic
Selecting motion diffusion: inverseDistance
 Reading stress mesh
[0] [1]
[1]
[1] --> FOAM FATAL ERROR:
[0]
[0] --> FOAM FATAL ERROR:
[0] Cannot find file "points" in directory "constant/solid/polyMesh"
[0]
[0]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
[0]     in file db/Time/findInstance.C at line 148
[1] Cannot find file "points" in directory "constant/solid/polyMesh"
[1]
[1]     From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
[1]     in file db/Time/findInstance.C at line 148.
[1]
FOAM parallel run exiting
[1]
[0]
[0]
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
mpirun has exited due to process rank 1 with PID 9060 on
node FOX-MS-7816 exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[FOX-MS-7816:09058] 1 more process has sent help message help-mpi-api.txt / mpi-abort
[FOX-MS-7816:09058] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
and I've found this information in log.makeLinks:
./Allrun: 55: ./Allrun: makeLinks: not found
How to fix it?
I'm still a new Linux user so I suppose that I made a mistake somewhere so thank you in advance for you help.
Bali likes this.
Woj3x is offline   Reply With Quote
Old   June 8, 2016, 05:36
Vaze
mvee is on a distinguished road
did you find any solution.
I am also facing similar trouble.
mvee is offline   Reply With Quote
Old   June 8, 2016, 06:13
Wojciech Gołąbek
Unfortunately I didn't find any information how to use fsiFoam in parallel
Probably it is necessary to modify the source code or wait for new version
Old   February 20, 2018, 18:23
Wei Meng
Tomko is on a distinguished road
Hi Wojciech, I am also facing the same problem too...Just wandering do you have any solutions now?
Tomko is offline   Reply With Quote
Old   January 13, 2019, 14:54
Stephen Waite
Stephen Waite is on a distinguished road
For anyone still having this problem, there is an example of parallel runs in the tutorial examples, fsiFoam/beamInCrossFlow. in foam-extended 4.0
You need to decompose both the solid and fluid domains
runApplication -l log.blockMesh.solid blockMesh -case ../solid
runApplication -l log.decomposePar.solid decomposePar -case ../solid -cellDist
runApplication decomposePar -cellDist
Both the solid and fluid case folders will need decomposeParDict files in their systems folders.
and make sure that you use
not
which most of the tutorial cases use because they are single core simulations, as then you will get the error,
Cannot find file "points" in directory "constant/solid/polyMesh".
This occurs because the polymesh folder of solid processor* has not been linked to the fluid processor* constant directory
Stephen Waite is offline   Reply With Quote
Old   September 3, 2019, 10:37
Post Please need urgent help
pjagdale1's Avatar
Pradeepkumar Jagdale
pjagdale1 is on a distinguished road
I am trying to solve FSI-foam in Parallel. I have done:
1) decomposePar for fluid and solid. (two subdomains each by scotch Method)
2) ./makeLinks fluid and solid
3) updated ./Allrun to ./AllrunPar using the tutorial fsiFoam/beamInCrossFlow.
But the case doesn't run
log.fsiFoam :
HTML Code:
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 4.0-268bb07d15d8
Date     : Sep 03 2019
Time     : 19:57:10
Host     : pradeep-HP-Pavilion-15-Notebook-PC
PID      : 24061
CtrlDict : "/home/pradeep/foam/parallelTest/HronTurekFsi3FE40/fluid/system/controlDict"
Case     : /home/pradeep/foam/parallelTest/HronTurekFsi3FE40/fluid
nProcs   : 2
Slaves :
1
pradeep-HP-Pavilion-15-Notebook-PC.24062
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
Create time
Selecting motion solver: refVelocityLaplacian
 Reading stress mesh
Creating traction displacement boundary conditions
Creating fixed displacement boundary condition
Selecting rheology model linearElastic
Creating constitutive model
Selecting coupling scheme Aitken
Starting time loop
Creating pointHistory function object.
[0] History point ID: 133
[0] History point coordinates: (0.6 0.201111 0.01)
[0] Reference point coordinates: (0.6 0.2 0.025334)
Creating hronTurekReport function object.
Time = 0.001 (dt = 0.001)
Create extended GGI zone-to-zone interpolator
Checking fluid-to-solid face interpolator
[pradeep-HP-Pavilion-15-Notebook-PC:24061] *** Process received signal ***
[pradeep-HP-Pavilion-15-Notebook-PC:24061] Signal: Segmentation fault (11)
[pradeep-HP-Pavilion-15-Notebook-PC:24061] Signal code:  (-6)
[pradeep-HP-Pavilion-15-Notebook-PC:24061] Failing at address: 0x3e800005dfd
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fe5631bf4b0]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fe5631bf428]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fe5631bf4b0]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 3] /home/pradeep/foam/foam-extend-4.0/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam7Pstream6gatherINS_5FieldINS_6VectorIdEEEENS_5sumOpIS5_EEEEvRKNS_4ListINS0_11commsStructEEERT_RKT0_ii+0x226)[0x7fe567afaa26]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 4] /home/pradeep/foam/pradeep-4.0/lib/linux64GccDPOpt/libfluidSolidInteraction.so(_ZN4Foam6reduceINS_5FieldINS_6VectorIdEEEENS_5sumOpIS4_EEEEvRT_RKT0_ii+0xc7)[0x7fe5651a6747]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 5] /home/pradeep/foam/pradeep-4.0/lib/linux64GccDPOpt/libfluidSolidInteraction.so(_ZNK4Foam19fluidSolidInterface19calcGgiInterpolatorEv+0x5f9)[0x7fe5654aed49]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 6] /home/pradeep/foam/pradeep-4.0/lib/linux64GccDPOpt/libfluidSolidInteraction.so(_ZNK4Foam19fluidSolidInterface15ggiInterpolatorEv+0x19)[0x7fe5654af539]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 7] fsiFoam[0x402d22]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fe5631aa830]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] [ 9] fsiFoam[0x4031d9]
[pradeep-HP-Pavilion-15-Notebook-PC:24061] *** End of error message ***
mpirun noticed that process rank 0 with PID 24061 on node pradeep-HP-Pavilion-15-Notebook-PC exited on signal 11 (Segmentation fault).
pjagdale1 is offline   Reply With Quote
Old   September 5, 2019, 00:40
Aashay Tinaikar
ARTisticCFD is on a distinguished road
Hello Guys,
Thanks for posting to this forum. Yes it can be run.
0) After blockMesh and setToZones command, run decomposePar separately from inside fluid/ and solid/
1) make a separate .sh file in fluid/ Eg: linkParallel.sh
2) Paste this inside it
for proc in processor0 processor1 processor2 .... processorN
do
echo $proc
cd $proc
cd 0
ln -s ../../../$2/$proc/0 solid
cd ../constant
ln -s ../../../$2/$proc/constant solid
cd ../..
done
3) If your makeSerialLinks.sh is one directory higher. Do
>> cd ..
>> ./makeSerialLinks.sh fluid solid
>> cd fluid/
4) Then execute the following
>> ./linkParallel.sh fluid solid"
This should create the links for individual processor domains.
5) Execute parallel run
>> mpirun -np <num_sub_domains> fsiFoam -parallel
I tested this myself. Hope this works for you too. Please let me know!
Cheers :-)
Last edited by ARTisticCFD; September 5, 2019 at 00:41. Reason: Random additional spaces between the lines
ARTisticCFD is offline   Reply With Quote
Old   September 5, 2019, 00:58
pjagdale1's Avatar
Originally Posted by ARTisticCFD View Post
Hello Guys,
do
echo $proc
cd $proc
cd 0
cd ../constant
cd ../..
done
>> cd ..
>> cd fluid/
Cheers :-)
Hi sir,
Can you please share your decomposeParDict file for solid and fluid (urgent requirement).
and regarding the file "makeLinks" there is some syntax error in the code. I have corrected it
makeLinks previously at line 20
foreach proc(processor*)
cd $proc
cd 0
cd ../constant
cd ../..
end
just modify it to
for proc in processor*
do
cd $proc
cd 0
cd ../constant
cd ../..
done
Thankyou.
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 11:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
