February 2, 2016, 11:36 |
Mesh runing in icoFoam , error message
Prasanna Welahettige
Rep Power: 10 |
Hai all,
Openfoam mesh file try to run in icoFoam in command window. I got following error. Please tell me the reason why this is happen --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 8.80626 Specified mass inflow : 7.78821 Specified mass outflow : 0 Adjustable mass outflow : 4.7956e-145 Thank you best regards, Prasanna. |
February 3, 2016, 04:33 |
Arsalan
Rep Power: 11 |
Check for your boundary conditions at the outlet (specially velocity BC)
Please explain more about your problem to get a better solution. Regards, Arsalan. |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
