Simulating full Vehicles
Old   February 3, 2016, 12:34
Default Simulating full Vehicles
Josh Dyson
jd210 is on a distinguished road
Hi All,
I've found myself a little stuck with a problem I'm working on.
I'm trying to simulate both external and internal flow around a car. Most of this is now second nature to me but the problem I'm encountering at the moment has me stumped.
I have a race car sidepod that I'm trying to simulate it has both a radiator and fan. I'm currently modelling both using the fanPressure boundary conditions to provide the pressure changes across both. What I can't work out is that as the radiator is sealed to the sidepod between it and the fan is a mesh unconnected to the mesh around the rest of the car and so should be discarded by snappyhexmesh. However I'd like to include this section in the simpleFoam computation as well.
I have tried defining faceZones and cellZones and using cellZoneInside, this seems to create a mesh in the region between the radiator and fan but when running simpleFoam there still seems to be no flow in this region.
Any thoughts or suggestions would be fantastic!
Josh
jd210 is offline   Reply With Quote
Old   March 13, 2016, 08:38
Artur's Avatar
Artur
Artur will become famous soon enough
If I understand correctly, your mesh effectively has two regions? This may be checked with checkMesh. If yes you probably need to be clever with how you couple them, and the answer is probably AMI. I am no expert in setting such simulations up so I cannot offer more than that I'm afraid.
There seems to be some interesting discussion here:
http://www.tfd.chalmers.se/~hani/OFG...lasJareteg.pdf
All the best,
A
Artur is offline   Reply With Quote
Rotor 67 full compressor geometry jf Main CFD Forum 3 January 28, 2024 05:14
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
[ICEM] Periodic mesh to Full mesh shivasluzz ANSYS Meshing & Geometry 0 October 5, 2015 12:01
Compressor Simulation Error- single passage to full domain!! Prak_32 CFX 0 March 17, 2015 04:20
Discrepancy ensight slice and full data for parallel decomposed case Japsor OpenFOAM Bugs 0 August 27, 2013 04:47
