Boundary conditions on suction problem (simpleFoam)
Old   March 16, 2016, 05:10
Default Boundary conditions on suction problem (simpleFoam)
thomas
thomas. is on a distinguished road
Hello all,
I am dealing with a 3D turbulent incompressible (air with M<0.3) suction problem case and I am quite confused regarding the correct boundary conditions I should be using, since I am not getting the expected flow. Solver: simpleFoam.
I am still struggling with the p and U boundary conditions, so I havenīt implemented a turbulence model yet. I would be eventually using k-omega-SST with wall functions. My mesh has about y+ = 1, since I read that the k-omega-SST turbulence model with wall functions supports meshes with y+ < 30.
The geometry has 2 inlets and one outlet, being one inlet an atmosphere-connected patch ("atm"). The other inlet ("inlet") has a constant volumetric flow rate. The outlet ("outlet") has a fixed pressure value (negative).
So far I have used following boundary conditions for each patch:
"inlet":
U => flowRateInletVelocity
p => zeroGradient / pressureInletVelocity
"atm":
U => zeroGradient / pressureDirectedInletVelocity
p => fixedValue (0)
"outlet":
U => zeroGradient / pressureInletOutletVelocity
p => fixedValue (-800)
With these boundary conditions I am actually getting flow out of the "atm"-patch and it is supposed to be the opposite of that.
Help would really be appreciated.
Thank you very much in advance!
Bye,
Thomas
thomas. is offline   Reply With Quote
Problem with Periodic Boundary Conditions Help!!! otsigun FLUENT 0 July 11, 2013 03:20
Boundary Conditions problem o_mars_2010 Main CFD Forum 2 July 8, 2013 02:10
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Problem with Boundary conditions Mahiboobswamulu Main CFD Forum 10 August 26, 2003 13:24
