substitution of mesh element with the force applied |
March 17, 2016, 02:58 |
Rep Power: 10 |
Hello everybody,
I want to simulate the behavior of a rheometer with a CFD-DEM solver, the geometry is available on the photograph. Now the internal element (the green one in the photo) is rotating with a certain rotation velocity omega. if I want to simulate it properly i should use a moving mesh, however I do not dispose of such an option and I was asking myself if it would be right to eliminate the internal element and apply to the solid phase and to the gas phase the force normaly exherted by the internal element, i.e. F/rho=omegaX(U), do you think this would do the trick? thanks to everybody for the attention and the help in advance, Riccardo Last edited by kurdt89; March 17, 2016 at 05:03. |
March 22, 2016, 02:50 |
Rep Power: 10 |
no one knows?
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
Force magnitude with moving mesh | fernexda | OpenFOAM Post-Processing | 3 | April 12, 2016 09:09 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ANSYS Meshing] max mesh element size | ulalala | ANSYS Meshing & Geometry | 8 | January 20, 2013 17:30 |
