May 18, 2016, 01:11 |
Unable to resume Simulation
GS
Rep Power: 10 |
I ran a simulation to end Time = 10. Now i wish to resume it.
I changed in controlDict file startTime = 10. but i am seeing Code:
--> FOAM FATAL IO ERROR: keyword grad(DU_0) is undefined in dictionary fvSchemes |
May 20, 2016, 03:02 |
Philipp
Rep Power: 26 |
This actually sounds like you changed something in your fvSchemes file.
Did you change the line under "gradSchemes" that was something like "default Gauss linear;"?
The skeleton ran out of shampoo in the shower. |
May 20, 2016, 04:01 |
GS
Rep Power: 10 |
Thank You for your concern!!
I have made no changes. Here is the fvSchemes code set in the tutorial itself. Code:
FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // d2dt2Schemes { default none; } ddtSchemes { default none; // ddt(DU) Euler; ddt(DU) backward; } gradSchemes { default none; grad(DU) Gauss linear; grad(Us) Gauss linear; snGradCorr(DU) Gauss linear; } divSchemes { default none; div(sigma) Gauss linear; } laplacianSchemes { default none; laplacian(DDU,DU) Gauss linear corrected; } snGradSchemes { default none; // snGrad(U) corrected; } interpolationSchemes { default none; interpolate(sigma) linear; interpolate(mu) linear; } // ************************************************************************* // Thanks Again |
May 20, 2016, 04:20 |
Philipp
Rep Power: 26 |
Since you set all of them to "Gauss linear" you can just set the default to Gauss linear and comment out the others. I don't know, why it didn't complain about the missing "grad(DU_0)" scheme before, but it is obviously missing.
January 25, 2017, 05:43 |
#5 | |
Instead of startTime use latestTime, I hope this will do the job. Best Luck ! |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 20, 2017 23:47 |
How to pause a transient simulation and resume without time step advancement? | aleisia | Main CFD Forum | 33 | June 12, 2017 11:41 |
Control simulation to apply different fields with chtMultiRegionFoam | jmdf | OpenFOAM Running, Solving & CFD | 0 | February 29, 2016 07:05 |
Supersonic Nozzle Exhaust Simulation | mikeh | FLUENT | 0 | May 1, 2014 21:28 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
