How to model release of steam to the atmosphere!
Like Tree2Likes
  • 2 Post By kcjarvis56
Old   October 25, 2017, 23:44
Default How to model release of steam to the atmosphere!
Sana Ullah
Mehar is on a distinguished road
Dear All,
I want to solve the problem of steam release to the atmosphere from a pressure relief valve. The release is expected at a height (~30m from ground) in vertically upward direction.
The conditions for pressure, temperature and flow rate are known at the release location, and the atmosphere is at ambient conditions.
My goal is to study how the flow develops once steam is released into open atmosphere, and how it will be affected by the wind.
I would really appreciate, if someone can guide on;
1) What could be good references to look for?
2) Which OpenFoam Solver could be used for modelling this problem?
3) If there are any modeling tips specifically for this kind of problem?
I have attached a simple diagram to explain the problem,
Thank you!
Mehar, Phd Scholar
KAIST, Korea
Mehar is offline   Reply With Quote
Old   October 26, 2017, 23:53
Kirk Jarvis
kcjarvis56 is on a distinguished road
1. Here is a reference for Vapor CO2 dispersion. Steam would be similar. Do a google search on openFoam atmosphere dispersion will also give you some more examples and papers. Mostly to do with dispersion of hazardous materials.
2. rhoReactingBuoyantFoam with reactions and chemistry off for dispersion models similar to what you are describing. Use rhoPimpleFoam example to get started with BC also reference reactingFoam.
3. You can use atmBoundaryLayer like the turbineSiting tutorial in the simpleFoam tutorial
directory. Make sure you have a good quality mesh.
raj kumar saini and Mehar like this.
kcjarvis56 is offline   Reply With Quote
Old   October 29, 2017, 06:58
Sana Ullah
Thank you Kirk Jarvis for your help.
I will definitely look into rhoPimpleFoam as a start for this problem.
Mehar, Phd Scholar
KAIST, Korea
multiphase flow, multiphase modelling, openfoam
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Wet Steam Model Martin007 Main CFD Forum 0 December 19, 2016 15:02
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Wet Steam model Spring.s FLUENT 0 October 8, 2011 02:24
What CFD package to model an atmosphere? Pedro Ferreira Main CFD Forum 7 February 2, 2008 07:44
