How can I create oscillatory flow with periodic boundary condition
Like Tree3Likes
  • 1 Post By joshwilliams
Old   March 20, 2023, 19:28
Default How can I create oscillatory flow with periodic boundary condition
Nazmul Islam
nazmulislam is on a distinguished road
I am trying to observe unsteady, laminar and incompressible flow through an axisymmetric periodic tube.
I have initialised the uniform velocity (along the tube axis) inside the tube and imposed periodic boundary conditions (cyclicAMI) at the inlet and outlet.
Now, I would like to create an oscillatory flow. I found a tutorial "pitzDailyPulse" with the solver "pimpleFoam" for laminar, incompressible flow. In this tutorial, the velocities are distributed at the inlet using the trigonometric COSINE function.
However, since I have imposed cyclicAMI boundary conditions at the inlet and outlet, I cant provide velocities at the inlet. It is mentioned that previously I tried to provide velocity at the inlet with cyclicAMI boundary conditions at the inlet and outlet, it did not work. For that reason, I initialised the uniform velocity inside the tube with cyclicAMI boundary conditions at the inlet and outlet and it worked. Please see more details in the following link:
Periodic BC for a Periodic Tube
I appreciate your suggestions in this regard.
Thanks in advance.
nazmulislam is offline   Reply With Quote
Old   March 21, 2023, 04:04
Josh Williams
joshwilliams is on a distinguished road
If your inlet and outlet should be periodic but you want to have oscillating flow, then I would think the only other option would be a time-varying source term (e.g. meanVelocityForce in fvOptions). I have not seen many examples where this is time-varying though. You may need to create your own library for this based on the meanVelocityForce implementation. Maybe there is already functionality for time-varying source term.
nazmulislam likes this.
joshwilliams is offline   Reply With Quote
Old   March 26, 2023, 21:04
Nazmul Islam
Hello Josh,
Many thanks for your kind suggestion and option to do this.
I am a new user in OpenFoam. So, could you please tell me more about this, preferably with an example?
Cheers,
Nazmul
Old   April 9, 2023, 07:54
Nazmul Islam
Hello Josh,
As you suggested I have created an fvOptions file (see in the attacment) consisting sinusoidal temporal function and put it in the system folder. However, it not working. That is, when I run the simulation using solver icoFoam, this file is not reading which is seen from the log file. I appreciate your kind suggestion in this regards. It is mentioned that I am using OpenFoam V10.
Cheers
Old   April 10, 2023, 12:27
Josh Williams
icoFoam.C does not call fvOptions as far as I am aware. Try pimpleFoam.
Old   April 10, 2023, 23:25
Nazmul Islam
Hi Josh,
Thanks again for your suggestion.
However, I have tried with pimpleFoam and received the fatal error message as you can see in the attachment:
It is mentioned that I have only added the fvOptions file as above in the system folder. Do I need to change any codes in any specific file in OpenFoam?
Please provide me your valuable suggestions in this regard.
Cheers
Old   April 11, 2023, 04:38
Josh Williams
Originally Posted by nazmulislam View Post
Hi Josh,
Cheers
It says you are missing keyword "format". i would check the source code or documentation to see what the keyword represents.
Old   April 13, 2023, 06:21
Nazmul Islam
Hi Josh,
Thanks for your suggestion. There was a semicolon missing after version 2.
Now, it is working.
Cheers
Wind tunnel flow simulation boundary condition issue charan3007 SU2 0 October 21, 2021 08:27
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
strange flow of pressure boundary adjacent periodic condition oilsok FLUENT 2 May 26, 2012 12:51
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
