InterFoam - solid suspension
Old   November 12, 2015, 06:23
Default InterFoam - solid suspension
Berat Loshi
Berati26 is on a distinguished road
Hi OpenFOAM Useres,
i´m trying to simulate with openFoam the sedimentation of Solid Particles in an Pool wich have an inlet and outlet. Im using InterFoam to simulate the internal Flow but i dont have any idea and if its possible to put Solit PArticles in the Flow... to see what heppen, do they transport with the flow ore do they suspend!?
can somebody help me for this with telling me were can i finde an controll datei and how its possible to simulate this with interFoam?
Best regards
Berati
Berati26 is offline   Reply With Quote
Old   November 12, 2015, 10:00
Saideep
Saideep is on a distinguished road
I guess generating a solid obstacle in the flow is straight forward. If you would like to have a simple structure like a square or so, you could do it directly using "blockMeshDict".
To have a more complicated and numerous number of obstacle objects its essential to use "snappyHexMesh" utility to generate a model for computation.
WRT suspension or obstruction of the solid particles, it completely depends upon a host of flow, model features such as shape of the model and obstacles, flow rates, fluid properties etc.
Saideep
Saideep is offline   Reply With Quote
Old   November 13, 2015, 04:41
Berat Loshi
Hello Saideep and thank u for your Answer.
Yes everything is klear, i have worked with blockMesh, and the simulation is running very well. The only thing what i dont know how to do is to put Solid Particles in the Flow. Its an Multiphasen case, with air und watter. An Trubulent flow. I cand find in the Tutorials an relevant case.
It musst be one way to do this with openFOAM So i hope someone here have do somthing like this bevor, or can me give some tips how to do this ?
Thank you
Best regards
Berati
Old   November 13, 2015, 06:36
cfdan is on a distinguished road
Something like this?
http://youtu.be/wBdoQhkVokk
cfdan is offline   Reply With Quote
Old   November 13, 2015, 15:51
Retired Super Moderator
Bruno Santos
Quick answer: This is not an easy thing to do.
As Saideep mentioned, you could simulate the particles as actual objects. For that there are two possible tutorials that might help:
  • multiphase/interDyMFoam/ras/floatingObject/
  • multiphase/interDyMFoam/ras/damBreakWithObstacle/
As for particle flow (solids that are so small that it's not possible to mesh them), you can try the tutorial "lagrangian/icoUncoupledKinematicParcelFoam/hopper", as briefly explained here: http://www.openfoam.org/version2.0.0/lagrangian.php
As for sedimentation... Google should help here... read this thread: http://www.cfd-online.com/Forums/ope...transport.html
Modelling falling solid sphere using interFoam VOF model eelcovv OpenFOAM Running, Solving & CFD 6 August 7, 2021 21:52
Defining solid zone in interFoam junewookee OpenFOAM Programming & Development 0 February 6, 2015 01:36
Suggest some papers on settling solid liquid flow / heterogeneous suspension flow Ruonin Main CFD Forum 2 July 23, 2012 07:50
solid suspension in moving liquid Jason FLUENT 4 October 27, 2003 18:59
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
