OpenFoam using chemkin to make new species
Old   April 6, 2011, 18:49
Default OpenFoam using chemkin to make new species
D.R. is on a distinguished road
I am using the chemkin solver to do a reaction for urea in my chem.inp file
ELEMENTS
C H O N
END
SPECIES
CH4N20 HNCO NH3 N2 O2 H2O NO
END
REACTIONS
CH4N2O => NH3 + HNCO 2.62E4 1.0 1.61E4
END
This seems like the correct solver, however, the molar fraction of urea stays constant and the NH3 and HNCO fractions do not increase, they stay at 0. Is there something wrong with this setup?
D.R. is offline   Reply With Quote
Old   April 7, 2011, 01:53
Karl-Johan Nogenmyr
kalle is on a distinguished road
Post your case (or as much of it as you are allowed to) and the output from the solver... then we have a possibility to see what's up!
kalle is offline   Reply With Quote
Old   April 7, 2011, 11:55
The reactions seem to not be taking place even though they should be.
here is the out.log file
Time = 0.24316
Evolving Spray
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 0.000111363, Final residual = 7.84706e-07, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.000130545, Final residual = 5.54606e-07, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 1.04772e-05, Final residual = 2.36695e-07, No Iterations 1
DILUPBiCG: Solving for CH4N2O, Initial residual = 0.000232098, Final residual = 7.27763e-07, No Iterations 2
DILUPBiCG: Solving for HNCO, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for NH3, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for O2, Initial residual = 9.70172e-05, Final residual = 5.69026e-07, No Iterations 2
DILUPBiCG: Solving for H2O, Initial residual = 7.13753e-05, Final residual = 3.23582e-07, No Iterations 2
DILUPBiCG: Solving for NO, Initial residual = 9.70173e-05, Final residual = 5.69026e-07, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 7.97133e-05, Final residual = 3.31688e-07, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.0116091, Final residual = 7.76861e-10, No Iterations 99
time step continuity errors : sum local = 2.56051e-13, global = 6.9169e-16, cumulative = -1.16239e-11
DICPCG: Solving for p, Initial residual = 0.00172367, Final residual = 8.31493e-10, No Iterations 91
time step continuity errors : sum local = 2.53289e-13, global = -2.82293e-15, cumulative = -1.16267e-11
DILUPBiCG: Solving for epsilon, Initial residual = 1.11152e-05, Final residual = 4.46099e-07, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1.33413e-05, Final residual = 3.01646e-07, No Iterations 1
Number of parcels in system.... | 322904
Injected liquid mass........... | 79.5796 mg
Liquid Mass in system.......... | 5.07001 mg
SMD, Dmax...................... | 35.3345 mu, 97.3992 mu
Added gas mass................. | 31.9709 mg
Evaporation Continuity Error... | -42.5387 mg
max T = max(T) [0 0 0 1 0 0 0] 1150 K
min T = min(T) [0 0 0 1 0 0 0] 824.49 K
ExecutionTime = 144825 s ClockTime = 145381 s
Courant Number mean: 0.0248724 max: 0.2412
Calculating averages
here is the chemistry properties in the constant folder
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format binary;
class dictionary;
location "constant";
object chemistryProperties;
psiChemistryModel ODEChemistryModel<gasThermoPhysics>;
chemistry on;
chemistrySolver ode;
initialChemicalTimeStep 1e-08;
sequentialCoeffs
cTauChem 0.001;
EulerImplicitCoeffs
cTauChem 0.05;
equilibriumRateLimiter off;
odeCoeffs
ODESolver SIBS;
eps 0.05;
scale 1;
Old   April 7, 2011, 16:27
figured out the problem, it was in the dieselFoam solver, i needed to comment out the turbulent time constant, because it caused instabilities in the chemistry solver, and was not necessary to the solution.
chem.inp, chemkin, urea
Solving for an additional species CO in coalChemistryFoam N. A. OpenFOAM Programming & Development 3 February 18, 2019 05:58
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 00:48
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
