Axialsymmetric VOF RANS
Old   January 27, 2009, 11:51
Default I'm running a 2D axial symmetr
Nat Trask
ntrask is on a distinguished road
I'm running a 2D axial symmetric case in rasInterFoam right now of a coaxial fuel injector. I'm getting seemingly random spurts of k and epsilon that shoot out of the symmetry axis and then die down. They form about 8 diameters downstream of the nozzle. Does anyone have experience with something like this? My boundary conditions are correct and the simulation runs fine with turbulence off. I'm using kEpsilon and wedge boundary conditions on the two planes.
Thanks,
Nat
ntrask is offline   Reply With Quote
Old   January 27, 2009, 23:24
Default I had strange results on an ax
Kirk Jarvis
kcjarvis56 is on a distinguished road
I had strange results on an axial symmetrical case where the symmetrical axis patch type was set to symmetryPlane. Without particle injection the case seamed to give reasonable results. Once the particle were injected all the particles collected on the symmetry axis.
Changing the axis plane patch to empty cleared up the issues. It was not clear in any of the documentation (I have access to) that the axis of symmetry should have an empty patch type.
I know it is a stab in the dark but thought it might help.
Kirk
kcjarvis56 is offline   Reply With Quote
Old   February 15, 2009, 13:09
Default Hi foamers! I'm simulating a
hamdi
hamcer is on a distinguished road
Hi foamers!
I'm simulating a case of a injercteur (axisymmetric) of a Pelton turbine with a flow twophasique water + air with the RANS turbulence model,
in other words, can I find a solver that treats the flow inside the nozzle and the flow twophasic outside of this injector at the same time, if there is someone who can help me for this,
I would be very grateful.
hamcer is offline   Reply With Quote
Old   February 15, 2009, 19:05
Default Take a look at rasInterFoam an
Nat Trask
Take a look at rasInterFoam and the dambreak tutorial.
On a related note, I noticed that the solver uses turbulence models that assume a constant density (clearly not applicable for two-phase flow). Does anyone have insight toward why that may be?
-Nat
Old   February 16, 2009, 04:40
Default thank you Nak ! I investigate
hamdi
thank you Nak !
I investigated the rasInterFoam tuturail, in fact it speaks about twophasique at 0 velocity, in addition it is not axisymmetric.
I do'nt know if there is something that speak about the flow inside of a cylindrical duct and jet at the same time with the RANS model.
Thank you again
Old   February 16, 2009, 10:17
Default You will want to use the rasIn
Nat Trask
You will want to use the rasInterFoam solver but create your own case. Take a look at the user guide to see how to change boundary conditions. lesInterFoam has a 2d axial symmetric mesh that you can take a look at.
LES, DNS and RANS Sas Main CFD Forum 14 May 16, 2012 03:35
U-RANS Corentin Main CFD Forum 7 July 3, 2008 17:51
LES or RANS ? TC FLUENT 1 July 13, 2007 16:16
Setting boundary condition BC on axialsymmetric problem axpl OpenFOAM Pre-Processing 2 April 19, 2007 08:28
RANS vs LES Pei Hsieh Main CFD Forum 2 April 27, 2005 08:40
