Coodles vs sonicTurbFoam
Old   April 26, 2005, 09:17
Default Dear OpenFOAM experts, Can
Pei-Ying Hsieh
hsieh is on a distinguished road
Can anyone here explain the differences between coodles and sonicTurbFoam?
Is there such thing as "steady state compressible (Mach .5 - 0.9) turbulent flow"? Thanks!
Pei
hsieh is offline   Reply With Quote
Old   April 26, 2005, 09:25
Default sonicTurbFoam: Transient RANS
Eugene de Villiers
eugene is on a distinguished road
sonicTurbFoam:
Transient RANS solver for trans-sonic/supersonic, turbulent flow of a compressible gas.
coodles:
LES solver for sub/trans-sonic turbulent flow of a compressible gas.
eugene is offline   Reply With Quote
Old   April 26, 2005, 10:13
Default Thanks Eugene! When using o
Pei-Ying Hsieh
Thanks Eugene!
When using oneEqEddy in LES, k is needed in /0/k. How is this k calculated for the inlet?
Pei
Old   April 26, 2005, 10:18
Default What kind of inlet are we talk
Eugene de Villiers
What kind of inlet are we talking about, i.e. fully/partially developed, laminar or slugflow?
Old   April 26, 2005, 10:51
Default Hi, Eugene, Last time I did
Pei-Ying Hsieh
Hi, Eugene,
Last time I did turbulence was 15 years ago. So, I am learning.
Inlet will be fully developed turbulent.
Is it LES generally more computational expensive than RANS? Especially, I have a complex geometry, so, may be I should stick to RANS kEpsilon model (I do not really want to resolve small flow structures)? Can you advise which solver will be appropriate for sub-sonic/transonic with kEpsilon model?
Thanks again for your help!
Pei
Old   April 26, 2005, 11:02
Default Ho! You definitely dont want t
Eugene de Villiers
Ho! You definitely dont want to be doing LES unless you have to. It is VERY expensive.
Try rhoTurbFoam for a compressible RANS solver, although I dont know how it will cope with trans-sonic flows. There is also sonicTurbFoam, but again this is not my area of expertise. Maybe someone who is more knowledgeable than me can give you some pointers on what the different RANS compressible codes do?
Old   April 26, 2005, 13:14
Default >Is there such thing as "stead
henry is on a distinguished road
rhoSimpleFoam
henry is offline   Reply With Quote
Old   April 26, 2005, 16:16
Default Thanks Henry! What rhoTurbF
Pei-Ying Hsieh
Thanks Henry!
What rhoTurbFoam is for? Is it suitable for mach .5?
Pei
Old   April 26, 2005, 17:02
Default rhoTurbFoam is for transient c
rhoTurbFoam is for transient compressible low-Ma laminar and turbulent flow and rhoSimpleFoam is for steady-state compressible low-Ma laminar and turbulent flow.
Old   February 3, 2009, 06:13
Default Hi fomers, I am running a
Vishal Jambhekar
vishal is on a distinguished road
Hi fomers,
I am running a case with sonicTurbFoam with 3 mach velocity at inlet. whare as inlet static temprature is 110 K and pressure is 0.15 bar.
I want to mainly capture the shock boundry layer interaction at inlet for air breathing engine.
Can you please tell me what outlet conditions should i apply. any other openions regarding any tool to plot static pressure along surface is also welcome. Plase help me in this issue.
Thanks
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   February 3, 2009, 06:17
Default Hi, One more thing is curre
  #11
Vishal Jambhekar
One more thing is currently i am using RNG K-Epsilon method. WHich scheme is best suite for capturing physics.
Thanks ij advance.
VIshal.
Cheers,
Vishal Jambhekar...
Coodles anja OpenFOAM Pre-Processing 33 January 14, 2010 09:05
Pressure waves bouncing around while using coodles ankgupta8um OpenFOAM Running, Solving & CFD 4 March 5, 2008 06:54
Pow in lib64tlslibmso6 SigFpe when running coodles with SpalartAllmaras lillberg OpenFOAM Bugs 4 December 7, 2007 08:17
Question about coodles tangd OpenFOAM Running, Solving & CFD 0 June 20, 2006 03:58
Startingsetting coodles on an academic case melanie OpenFOAM Running, Solving & CFD 5 March 30, 2006 04:00
