Always crash when solve a C-D nozzle flow field using rhoCentralFoam |
March 9, 2011, 06:13 |
Hawk
Rep Power: 15 |
dear all:
I have used the rhocentralFoam in OpenFoam to solve an CD nozzle with subsonic inlet and supersonic outlet. But there is always an error after serval iteration steps even if I have tried varied boundary conditions for the case (you can find them in the notes of the P、U、T files in the 0 folder). Fluent mesh file and source files can be found in the attachments. Can anyone give me some advice? thanks! source code"0" FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1013250; boundaryField { symmetry.5 { type symmetryPlane; } wall.2 { type zeroGradient; } /* pressure_inlet.3 { type totalPressure; p0 uniform 1.01325e+06;//_in U U; phi phi; rho none; psi none; gamma 1.4; value uniform 1.01325e+06; } */ /* pressure_outlet.4 { type waveTransmissive; value uniform 100; field p; gamma 1.4; phi phi; rho rho; psi psi; lInf 1; fieldInf 100; }*/ pressure_inlet.3 { type fixedValue; value uniform 1.01325e+06; } pressure_outlet.4 { type zeroGradient; } frontAndBackPlanes { type empty; } } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 2000; boundaryField { symmetry.5 { type symmetryPlane; } wall.2 { type zeroGradient; } pressure_outlet.4 { type zeroGradient; } pressure_inlet.3 { type fixedValue; value uniform 2000; } frontAndBackPlanes { type empty; } } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (30 0 0); boundaryField { symmetry.5 { type symmetryPlane; } wall.2 { type fixedValue; value uniform (0 0 0); } pressure_outlet.4 { type zeroGradient; } pressure_inlet.3 { type pressureInletVelocity; // type pressureDirectedInletOutletVelocity; value uniform (30 0 0); } frontAndBackPlanes { type empty; } } // ************************************************** *********************** // source code "constant" FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>; mixture air 1 28.9 717.5 0 1.82e-05 0.73; //thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>; //mixture air 1 28.9 1007 0 1.84e-05 0.7; // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType laminar; // ************************************************** *********************** // source code"system" FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application rhoCentralFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 100; deltaT 1e-4; writeControl adjustableRunTime; writeInterval 1e-1; cycleWrite 0; writeFormat ascii; writePrecision 15; writeCompression uncompressed; timeFormat general; timePrecision 6; adjustTimeStep yes; maxCo 0.2; maxDeltaT 1; // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(tauMC) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) MUSCL; reconstruct(U) MUSCLV; reconstruct(T) MUSCL; } snGradSchemes { default corrected; } // ************************************************** *********************** // FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { rho { solver diagonal; } rhoU { solver diagonal; } rhoE { solver diagonal; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-09; relTol 0.01; } e { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-10 relTol 0; } } // ************************************************** *********************** // |
Stability Problem with sonicFoam for Nozzle Flow | Julian K. | OpenFOAM | 3 | July 11, 2016 08:14 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Nonphysical flow field while using coodles solver | ankgupta8um | OpenFOAM Running, Solving & CFD | 5 | January 26, 2008 16:54 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
