Always crash when solve a C-D nozzle flow field using rhoCentralFoam
Old   March 9, 2011, 06:13
Question Always crash when solve a C-D nozzle flow field using rhoCentralFoam
Hawk
hawklion is on a distinguished road
dear all:
I have used the rhocentralFoam in OpenFoam to solve an CD nozzle with subsonic inlet and supersonic outlet.
But there is always an error after serval iteration steps even if I have tried varied boundary conditions for the case (you can find them in the notes of the P、U、T files in the 0 folder).
Fluent mesh file and source files can be found in the attachments.
Can anyone give me some advice?
thanks!
source code"0"
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1013250;
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type zeroGradient;
/* pressure_inlet.3
type totalPressure;
p0 uniform 1.01325e+06;//_in
U U;
phi phi;
rho none;
psi none;
gamma 1.4;
value uniform 1.01325e+06;
pressure_outlet.4
type waveTransmissive;
value uniform 100;
field p;
gamma 1.4;
phi phi;
rho rho;
psi psi;
lInf 1;
fieldInf 100;
pressure_inlet.3
type fixedValue;
pressure_outlet.4
type zeroGradient;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 2000;
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type zeroGradient;
pressure_outlet.4
type zeroGradient;
pressure_inlet.3
type fixedValue;
value uniform 2000;
frontAndBackPlanes
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (30 0 0);
boundaryField
symmetry.5
type symmetryPlane;
wall.2
type fixedValue;
value uniform (0 0 0);
pressure_outlet.4
type zeroGradient;
pressure_inlet.3
type pressureInletVelocity;
// type pressureDirectedInletOutletVelocity;
value uniform (30 0 0);
frontAndBackPlanes
type empty;
source code "constant"
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object thermophysicalProperties;
thermoType ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>;
mixture air 1 28.9 717.5 0 1.82e-05 0.73;
//thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
//mixture air 1 28.9 1007 0 1.84e-05 0.7;
FoamFile
version 2.0;
format ascii;
class dictionary;
object turbulenceProperties;
simulationType laminar;
source code"system"
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application rhoCentralFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 100;
deltaT 1e-4;
writeControl adjustableRunTime;
writeInterval 1e-1;
cycleWrite 0;
writeFormat ascii;
writePrecision 15;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
adjustTimeStep yes;
maxCo 0.2;
maxDeltaT 1;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
fluxScheme Kurganov;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(tauMC) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
reconstruct(rho) MUSCL;
reconstruct(U) MUSCLV;
reconstruct(T) MUSCL;
snGradSchemes
default corrected;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
rho
solver diagonal;
rhoU
solver diagonal;
rhoE
solver diagonal;
U
solver smoothSolver;
smoother GaussSeidel;
nSweeps 2;
tolerance 1e-09;
relTol 0.01;
e
nSweeps 2;
tolerance 1e-10 relTol 0;
hawklion is offline   Reply With Quote
Stability Problem with sonicFoam for Nozzle Flow Julian K. OpenFOAM 3 July 11, 2016 08:14
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Nonphysical flow field while using coodles solver ankgupta8um OpenFOAM Running, Solving & CFD 5 January 26, 2008 16:54
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
