February 20, 2008, 03:56 |
Hello
First post on the mes
Juho Peltola
Rep Power: 17 |
Hello
First post on the message board. I've only begun looking into OpenFOAM a few weeks ago. I'm trying to simulate a intake plenum of a car and I'm using rhoTurbFoam. My problem is how to define the time dependant boundary conditions for the outlets to each cylinder. In a test case I currently have defined them as: =============================================== 0/U: out1 { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } inlet { type pressureInletOutletVelocity; phi phi; value uniform (0 0 0); } 0/p: out1 { type timeVaryingUniformFixedValue; timeDataFileName ".../out1p.dat"; value uniform 100000; } inlet { type totalPressure; U U; phi phi; rho none; psi none; gamma 1; p0 uniform 100000; value uniform 100000; } =============================================== The out1.dat has a period of constant inlet pressure followed by a sine curve of a lower pressure. This setup gives something resembling the boundary conditions I want but it's not really correct. I would like to change the type of the boundary depending on time: =============================================== T1: =============================================== p: out1 { type timeVaryingUniformFixedValue; timeDataFileName ".../out1p.dat"; value uniform 100000; } U: out1 { type zeroGradient; } =============================================== T2: =============================================== p: out1 { type zeroGradient } U: out1 { type fixedValue; value uniform (0 0 0); } =============================================== Is there an easy way to accomplish this? Or is there a better way to approach the issue all together? I would greatly appreciate any help or guidance! Juho |
February 21, 2008, 02:17 |
At first glance, it would seem
Mark Olesen
Rep Power: 40 |
At first glance, it would seem that you need to write a time-varying mixed boundary condition and use the mixing parameter to switch between the value and the gradient.
The example input file might look like this: // time fraction refValue refGradient // using 10m/s ( 0.1 1 10 0) ... // using zero-gradient ( 0.2 0 10 0) /mark |
February 21, 2008, 09:21 |
Thank you!
I'll start looki
Juho Peltola
Rep Power: 17 |
Thank you!
I'll start looking into writing a timeVaryingMixed boundary condition. Let's see how it goes... Juho |
December 8, 2008, 04:03 |
Hi, Juho
I'm also intereste
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
Rep Power: 17 |
Hi, Juho
I'm also interested on timeVaryingMixed boundary condition. Have you successfully done it ?? Florian |
February 17, 2010, 00:41 |
#5 | |
Rep Power: 17 |
Hi Juho, Floooo, Did you get anywhere with your Boundary Condition problems? I too am looking at developing a time based BC that changes from an inlet to a wall at a specified time during the run. I am looking at using an IF, THEN, ELSE statement within the condition code to try and get it working, however so far I have had no luck. If you have had any success with your problems, then I would love to hear about it! R |
May 26, 2019, 19:04 |
Nadun Palmada
Rep Power: 9 |
Hi rassilon
Did you manage to figure out how to achieve this? Thanks Nadun |
Time varying inlet boundary conditions | gbansal | OpenFOAM Running, Solving & CFD | 1 | August 16, 2008 22:47 |
time varying boundary condition | cfd-student | CFX | 0 | April 15, 2008 08:31 |
How to change boundary type at calculation time? | Stanislav Kraev | FLUENT | 0 | December 4, 2006 03:33 |
Time Varying Boundary Conditon | ashish | CFX | 3 | February 15, 2005 06:21 |
time varying boundary condition | co2 | FLUENT | 2 | November 11, 2003 12:36 |
