Steady incompressible laminar flow using simpleFoam
Old   October 29, 2008, 15:28
Default Someone posted a message about
yongshenglian
Someone posted a message about using simpleFoam to solve steady incompressible flow problem. I just cannot find it anymore.
After reading some papers and posted messages here, I made a new solver based on simpleFoam. It took me a while to compile the solver but finally I have the executable file. However, the solution is always wrong. The velocity is more than 100 times of the inlet velocity over a channel.
I checked my code and compare with simpleFoam. It does not seem that the code is wrong. I also check the boundary condition and initial condition. IF I run PISO, it gives good result.
I post the code here. Hopefully someone can correct me.
Thanks.
#include "fvCFD.H"
//#include "incompressible/singlePhaseTransportModel/singlePhaseTransportModel.H"
//#include "incompressible/RASModel/RASModel.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
# include "createFields.H"
# include "initContinuityErrs.H"
Info<< "\nStarting time loop\n" << endl;
for (runTime++; !runTime.end(); runTime++)
Info<< "Time = " << runTime.timeName() << nl << endl;
# include "readSIMPLEControls.H"
# include "initConvergenceCheck.H"
p.storePrevIter();
// Solve the Momentum equation
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
+ fvm::laplacian(nu,U)
UEqn().relax();
eqnResidual = solve
UEqn() == -fvc::grad(p)
).initialResidual();
maxResidual = max(eqnResidual, maxResidual);
// pressure correction
p.boundaryField().updateCoeffs();
volScalarField AU = UEqn().A();
U = UEqn().H()/AU;
UEqn.clear();
phi = fvc::interpolate(U) & mesh.Sf();
adjustPhi(phi, U, p);
// Non-orthogonal pressure corrector loop
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix pEqn
fvm::laplacian(1.0/AU, p) == fvc::div(phi)
pEqn.setReference(pRefCell, pRefValue);
// retain the residual from the first iteration
if (nonOrth == 0)
eqnResidual = pEqn.solve().initialResidual();
else
pEqn.solve();
if (nonOrth == nNonOrthCorr)
phi -= pEqn.flux();
# include "continuityErrs.H"
// Explicitly relax pressure for momentum corrector
p.relax();
// Momentum corrector
U -= fvc::grad(p)/AU;
U.correctBoundaryConditions();
runTime.write();
# include "convergenceCheck.H"
Info<< "End\n" << endl;
return(0);
SimpleFoam as Newtonian laminar flow solver titio OpenFOAM Running, Solving & CFD 2 March 8, 2013 04:44
Steady state incompressible flow Bharat Rangan (Rangan) OpenFOAM Running, Solving & CFD 10 November 22, 2010 15:21
Incompressible laminar poiseuille flow samarth OpenFOAM Running, Solving & CFD 20 July 13, 2010 03:38
SimpleFoam for laminar flow hsing OpenFOAM Running, Solving & CFD 3 April 14, 2005 14:39
incompressible steady flow john Main CFD Forum 0 May 9, 2003 08:24
