Problem with turbFoam
Old   September 29, 2008, 15:06
Default Hi All, I need some clarifi
Senthil Kabilan
skabilan is on a distinguished road
Hi All,
I need some clarification with the Kepsilon turbulence model. I have computed a steady state solution for the following geometry (Figure A) using simpleFoam with Kepsilon model. The boundary conditions include a zero pressure at the inlet and a pressure of -10 pa at all the eight outlets. There was no problem with the convergence. On investigating the results, the pressure at the cross section AA` was -3.91 pa and the mass flux was 1.77e-04 m^3/sec.
I have another geometry (Figure B), which is a subset of the aforementioned model. When a pressure of -3.91 pa was applied at the two outlets with no change in any of the boundary or the solver settings, the expectation was that the massflux would be ~1.77e-04 m^3/sec (at the same location). Instead it was 1.94e-04 m^3/sec. So I fine-tuned the pressure at the outlets to match the massflux of 1.77e-04 m^3/sec. The final pressures at the two outlets which yielded a massflux of 1.77e-04 m^3/sec was – 3.47 pa.
My question is… why do I see a difference of 11.03% in pressure for the same massflux and the same geometry? Am I missing something? Any thoughts or suggestions?
Thanks
Senthil Kabilan
skabilan is offline   Reply With Quote
Old   September 29, 2008, 17:09
Default Hi Senthil, One guess: If y
Ola Widlund
olwi is on a distinguished road
Hi Senthil,
One guess: If you look at the velocity distribution in the outlets of Geometry B, and compare with equivalent cross-section in Geometry A, the velocity distributions in the cross-section are probably not the same.
I am not chocked by the differences you see. The mathematical properties of a boundary condition does differ from that of an arbitrary cross-section in the middle of a developing flow. As a general rule, boundary conditions should be placed some distance away from the regions you're really interested in, and/or in a zone of well-developed flow.
/Ola
olwi is offline   Reply With Quote
Old   September 29, 2008, 17:43
Default Hi Ola, Thanks for the feed
Senthil Kabilan
Hi Ola,
Thanks for the feedback! So there is nothing wrong in what I see. It is just the way it is!
Hrv: Thanks for the email.
Regards,
Senthil
HELP NEEDED with TURBFOAM dinonettis OpenFOAM Running, Solving & CFD 64 June 22, 2010 09:58
TurbFoam diverge ivanyao OpenFOAM Running, Solving & CFD 6 January 11, 2009 07:41
Problem with turbFoam sivakumar OpenFOAM Pre-Processing 7 August 28, 2008 04:45
TurbFoam hsieh OpenFOAM Running, Solving & CFD 12 July 23, 2008 07:40
Problem about wmake turbFoam williamscn OpenFOAM Running, Solving & CFD 3 September 19, 2007 11:55
