Implicit solver for gamma volumefraction equation
Like Tree8Likes
Old   June 20, 2007, 11:19
Default Cuurently, the volume-fraction
sek
Sung-Eun Kim
sek is on a distinguished road
Cuurently, the volume-fraction equation in interFoam, for instance, uses an explicit solver. I was curious whether using an implicit solver would allow me to use larger time-step size. So, I tried to call MULES::implicitSolve01 instead of MULE::explicitSolve1 in gammaEqn.H. It seems to work. One thing I'm not sure about is one of the argument Dpsi of dimensionedScalar type. Looking at the MULE implementation, Dpsi of appears to be a diffusivity introduced as a stabulity measure for gamma equation. I set it to a small value, which seems to work.
Can someone comment on whether I'm doing things right, please?
sek is offline   Reply With Quote
Old   September 9, 2008, 07:42
Default Hi all I would like to rest
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi all
I would like to restart this discussion. Is there anyone who has successfully implemented an implicit solver for the gamma equation?
I tried the above approach but was not able to get it to work.
Further, what is the argument behind the hard-coded "MULES::explicitSolve01" in the interFoam-solvers.
I am currently using 1.4.1.
Thank you for any help or suggestions.
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 9, 2008, 12:12
Default MULES::implicitSolve works wit
Patricio Bohorquez
pbohorquez is on a distinguished road
MULES::implicitSolve works with success in the solver interPhaseChangeFoam (OF-1.5).
Following src/finiteVolume/fvMatrices/solvers/MULES/MULES.H it reads
MULES:explicitSolve01(psi, phi, phiPsi) ask you for:
- psi: actual value of the variable to be solved
- phi: normal convective flux
- psiPhi: actual explicit flux of the variable to solve. It is also used to return the limited flux of the bounded solution.
Obviously, psi = gamma for interFoam. Then, phi = U·S, where U is the velocity vector and S is the normal to the cell surface times the cell-surface area. Its value comes from the PISO-loop. Finally, psiPhi = gamma [U+(1-gamma)U<sub>r,gamma</sub>]·S = gamma U<sub>gamma</sub>·S, where U<sub>r,gamma</sub> is the relative velocity of the water with respect to the air at the thick free-surface, and U<sub>gamma</sub> is the velocity of the gamma-phase.
Patricio
Pirlu and liliang like this.
pbohorquez is offline   Reply With Quote
Old   September 10, 2008, 05:53
Default Hi Patricio Thanks for the
ngj
Hi Patricio
Thanks for the quick answer. I will download 1.5. and look into it.
Best regards,
Niels
Old   September 12, 2008, 09:06
Default Hi all I have tried to find
ngj
Hi all
I have tried to find some documentation on the MULES-procedure, but on Web of Science I can only find references to the "animal"-kind of MULES.
Further in Henrik Ruches he describes what looks like the used procedure, but refer to a N_a_b_l_a Ltd technical note.
Thus is is possible that
H.G.Weller, Derivation, modelling and solution of the conditionally averaged two-phase flow equations. Technical Report TR/HGW/02, N_a_b_l_a Ltd, 2002
could be made available? If anyone knows another source of documentation I would be happy to know about it.
Best regards and a good weekend to all,
Niels
Old   September 12, 2008, 10:50
Default MULES was invented by Henry la
Eugene de Villiers
eugene is on a distinguished road
MULES was invented by Henry last year (or was it 2006?) and nothing has ever been published, so you aren't likely to find any documentation about it.
eugene is offline   Reply With Quote
Old   September 13, 2008, 05:20
Default Hi @Eugene Okay, I am s
ngj
Hi
@Eugene
Okay, I am sorry to hear that, but there is of course nothing to do about it.
@Other
I have tried to shift to a MULES::implicitSolver in interFoam, but I keep running it problems with my fvSolution file. From the source "MULESImplicit" should be a subDict in the gamma-solution file, thus I have added this to the file:
gamma PBiCG
MULESImplicit
maxIter 1000;
nLimiterIter 10;
maxUnboundedness 1;
CoCoeff 0.2;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
thus even though I have added it as a subDict, I keep getting this error message:
keyword MULESImplicit is undefined in dictionary "/home/ngj/OpenFOAM/ngj-1.5/run/tutorials/interFoam/damBreak/system/fvSolution:: gamma"
file: /home/ngj/OpenFOAM/ngj-1.5/run/tutorials/interFoam/damBreak/system/fvSolution::g amma from line 47 to line 54.
From function dictionary::subDict(const word& keyword)
in file db/dictionary/dictionary.C at line 288.
FOAM exiting
Thus if any knows how to set the gamma-part of fvSolution, then please help.
Best regards,
Niels
P.S. For any, do not take the values in the subDict seriously, as I have not looked into the meaning behind those yet.
Old   September 13, 2008, 07:16
Default Hi Niels! I am sorry that I
Kevin Maki
kjmaki is on a distinguished road
Hi Niels!
I am sorry that I can't help you with the MULESImplicit, but I find it strange that the MULESExplicit controls are read from the PISO dict, and the Implicit are from the gamma dict. Do you know why they would do that?
Also, there is some mention on the gamma transport equation that FOAM uses in the thesis by Rusche (2002), sec 4.2.1. You will see that it references private communication with Weller for the details though.
Have a great weekend!
Kevin
kjmaki is offline   Reply With Quote
Old   September 13, 2008, 08:31
Default Hi Niels I suppose that you
Patricio Bohorquez
Hi Niels
I suppose that you have replaced the files gamma* of interFoam with those from interPhaseChangeFoam, commented the lines related to Sp & Su in gammaEqn.H and call MULES::implicitSolve(oneField(), gamma, phi, phiGamma, zeroField(), zeroField(), 1, 0); (or similar)
Then you must try this option instead of the one you proposed:
gamma
MULESImplicit
maxIter 1000;
nLimiterIter 10;
maxUnboundedness 1;
CoCoeff 0.2;
solver PBiCG
tolerance 1e-06;
relTol 0;
and add to fvSchemes the following line:
div(rhoPhi,U) Gauss limitedLinearV 1; It works.
Patricio
Old   September 13, 2008, 08:36
Patricio Bohorquez
Hi Niels
gamma
MULESImplicit
maxIter 1000;
nLimiterIter 10;
maxUnboundedness 1;
CoCoeff 0.2;
solver PBiCG
tolerance 1e-06;
relTol 0;
and add to fvSchemes the following line: div(rhoPhi,U) Gauss limitedLinearV 1; It works. I have sent a message to your email with the files
Patricio
Old   September 13, 2008, 11:59
Default Hi Patricio Yes, I have cha
  #11
ngj
Hi Patricio
Yes, I have changed the gamma* files, and I will get to work a.s.a.p.
Again, thanks for your kind help.
/ Niels
Old   September 14, 2008, 14:57
Default Dear Niels, i have been fol
  #12
caw
Christian Winkler
caw is on a distinguished road
Dear Niels,
i have been following up this thread and tried the impicit version of interFoam myself.
Out of curiosity: What do you try to achive by using an implicit formulation for the gamma equation?
And do you succeed?
Thing that spring to my mind:
- stability -> higher time steps
- steady state solutions
Could you comment on that please?
Best regards
Christian
caw is offline   Reply With Quote
Old   September 16, 2008, 08:30
Default Hi Christian Sorry for the
  #13
ngj
Hi Christian
Sorry for the wait, I am in the middle of a not-coorporating reinstall, so I will make it short.
The actual goal was to consider if the implicit solver did give raise to a different exchange of energy between water and air. I, and I know others have the same problem, get large velocities in the air phase, significantly larger than the wave propagation speed.
Due to reinstallation, I have not reached a conclusion, thus this is the closests I can get.
Generally I have not experienced instability problems with waves, except if they break and I use a laminar solver, then the energy cannot be dissipated at a significantly large enough rate.
Best regards,
Niels
Pirlu likes this.
Old   April 6, 2009, 10:42
SJ
santhanuj is on a distinguished road
can anyone tell me how the relative velocity is calculated???
santhanuj is offline   Reply With Quote
Old   June 29, 2009, 13:27
isabel
isabel is on a distinguished road
I need to solve the gamma equation in interFoam. But I want to add a source as that:
d(gamma)/dt + div(U*gamma) + div(phigamma) = source
How can I do this? Perhaps with this line: ?
MULES:: implicitSolve(gamma,phi,phiGamma,source)
isabel is offline   Reply With Quote
Old   June 30, 2009, 05:39
ngj
Hi Isabel
Please look into the source in the folder:
~/OpenFOAM/src/finiteVolume/fvMatrix/solvers/MULES
and you will be able to find out about the syntax.
Best regards,
Niels
Old   June 30, 2009, 07:54
isabel
Thank you very much, ngj
The key is in MULESTemplates.C in these lines:
fvScalarMatrix psiConvectionDiffusion
fvm::ddt(rho, psi)
+ fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi)
- fvm::Sp(Sp, psi)
- Su
I think that the equation that it is solving is:
d(rho*psi)/dt + div(phi*psi) - Sp*psi - Su = 0
Am I right?
Old   July 7, 2009, 04:29
Sandy Lee
sandy is on a distinguished road
fvm::ddt(rho, psi)
- fvm::Sp(Sp, psi)
- Su
Am I right?
Hi, it seems that you lost the compressible term: div(gamma*(1-gamma)*phi). I guess the gamma equation should be as follows:
d(rho*gamma)/dt + div(phi*gamma) + div(gamma*(1-gamma)*phi) - Sp*gamma - Su = 0
In MULESTemplates.C,
phiPsi = phiGamma = phi*gamma + gamma*(1-gamma)*phi
is it right? If that, in gammaEqu.H, why Su = divU*gamma + vDotcAlphal ? It look like that the term divU*gamma was repeatedly solved ??
I knew, to the gamma transport equation,
Source term = vDotvAlphal * gamma + (1 - gamma) * vDotcAlphal = (vDotvAlphal - vDotcAlphal) * gamma + vDotcAlphal.
So, Sp = (vDotvAlphal - vDotcAlphal) * gamma , and it will be solved implicitly.
Su = vDotcAlphal, and it is an explicit term in this equation.
but again, why Su also includes the term divU*gamma in gammaEqu.H ? If the MULES::implicitSolver was chose, this term should be deleted, right?
sandy is offline   Reply With Quote
Old   July 7, 2009, 13:28
isabel
Thank you very much, sandy.
I have been studying the interPhaseChange solver carefully.
As you say, in gammaEqn.H we define the variable phigamma:
phigamma = phi*gamma + gamma*(1-gamma)*phir
Sp = vDotvAlphal – vDotcAlphal
Su = div(U)*gamma + vDotcAlphal
And then, when we execute MULES::explicitSolve(oneField(),gamma,phi,phiGamma ,Sp,Su,1,0);
we associate:
rho → oneField ()
psi → gamma
phi → phi
phiPsi → phigamma
Sp → Sp
Su → Su
psiMax → 1
psiMin → 0
and then, the key is in this lines of MULESTemplates.C:
fvm::ddt(rho, psi)
- fvm::Sp(Sp, psi)
- Su
solve
psiConvectionDiffusion + fvc::div(lambda*phiCorr),
MULEScontrols.lookup("solver")
That I think that the equation is
d(1*psi)/dt + div(phigamma) + Sp*gamma - Su = 0
I don't know what means this line:
but I think you are right, div(U) is repeated. I will ask for my advisors and I will confirmate.
Do you know what these lines means?
slicedSurfaceScalarField lambda
IOobject
"lambda",
mesh.time().timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE,
false
mesh,
dimless,
allLambda,
false // Use slices for the couples
Pirlu likes this.
Old   July 7, 2009, 19:20
Sandy Lee
IOobject
"lambda",
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE,
false
mesh,
dimless,
allLambda,
);[/QUOTE]
Hi isabel, you have a great advisor, right? You are lucky. I think, in above code, lambda = allLambda, if you want know more informations about it, you can change the code as follows:
IOobject
"lambda",
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE,
false
mesh,
dimless,
allLambda,
Then, you can get an detailed output file in every iterative step about the "lambda" field.
By the way, this kind of method can also help us to easily debug the codes in OF.
But, now I still don't know what means this line:
fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi), and how to deal with the divU*gamma of Su ..... if you know them, please let me know too. Thanks.
Euler Equation Implicit Upwind Schemes felixrieper OpenFOAM Running, Solving & CFD 1 February 9, 2014 00:58
FEM pressure poisson equation (Implicit) cfd-beginner Main CFD Forum 0 August 9, 2005 13:32
Compressive term in gamma equation Ali (Ali) OpenFOAM Running, Solving & CFD 0 February 17, 2005 17:19
Implicit equation solving Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 2 December 10, 2004 05:36
implicit solver john Siemens 1 November 11, 2003 08:55
