Finitedifference solver
Old   February 5, 2008, 11:34
Default Is OpenFOAM only for finite-vo
Anurag Agarwal
anurag is on a distinguished road
Is OpenFOAM only for finite-volume/finite-element schemes? Is it possible to use OpenFOAM for a finite-difference time-domain (FDTD) calculation? I would like to implement at high-order FDTD method for an aeroacoustic application. Thanks.
Regards,
Anurag
anurag is offline   Reply With Quote
Old   February 5, 2008, 19:45
Default Hi Anurag, Sounds interesti
Takuya OSHIMA
7islands is on a distinguished road
Hi Anurag,
Sounds interesting. While it might be possible to implement higher order / compact finite-difference schemes (which usually require structured stencils) if you make assumptions for mesh to be structured (in cell number ordering, connectivity constraints, etc), its performance will be worse than the dedicated FDTD codes written e.g. in Fortran. When I once compared computational time and memory footprint between an OpenFOAM code (with usual finite-volume formulation though) and a dedicated Fortran FDTD code in a simple acoustic wave propagation problem, both were more than 10 times worse in OpenFOAM code (Still I usually use the OpenFOAM code... its flexibility and versatility well more than compensates the performance difference). However it's only my personal view, OpenFOAM experts' opinions may differ.
Takuya
7islands is offline   Reply With Quote
Old   September 10, 2008, 09:16
Default Hi guys! Did you success to w
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi guys!
Did you success to write something like an high order finite difference-like scheme in OpenFOAM?
I'm interested too in it, as I'm working on aeroacoustics...
Do you think about some other high order techniques, like DRP Finite Volume or Discontinuous Galerkin Methods? Anyone knows if it is possible to implement something like this in OpenFOAM?
I know that there's a FEM tool in OpenFOAM, where can I find some documentation on it? Maybe with it is possible to try to implement a Discontinuous Galerkin Method...
ivan_cozza is offline   Reply With Quote
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 01:24
about CFX solver student CFX 3 April 6, 2006 19:02
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver dandes OpenFOAM Pre-Processing 0 March 22, 2006 21:06
solver fuf FLUENT 0 June 19, 2003 13:54
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 08:30
