FOAM FATAL IO ERROR
Old   October 15, 2006, 20:34
Default Can someone help me with this
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Can someone help me with this error message that shows up when I run icoFoam in parallel.
[0] --> FOAM FATAL IO ERROR : Expected a '(' while reading VectorSpace<form,>, found on line 0 the doubleScalar 13.2233
[0]
[0] file: IOstream at line 0.
[0]
[0] From function Istream::readBegin(const char*)
[0] in file db/IOstreams/IOstreams/Istream.C at line 94.
[0]
msrinath80 is offline   Reply With Quote
Old   October 16, 2006, 04:33
Default Check which file that number i
Mattijs Janssens
mattijs is on a distinguished road
Check which file that number is in. Something is trying to read a vector/point.
set the environment variable FOAM_ABORT and run the different processes each in a different window in a debugger. Have a look at the lamrun script (posted here before)
mattijs is offline   Reply With Quote
Old   October 17, 2006, 02:16
Default Thanks Mattijs. I solved the p
Thanks Mattijs. I solved the problem somehow. I'll soon post the solution here. Once again, I appreciate your help
Old   July 30, 2008, 06:07
Default hi pUI, relating to ur post
mayank gupta
mgz1985 is on a distinguished road
hi pUI,
relating to ur post of doubleScalar errors, can u plese tell me the solutionas i m facing the same problem while defining a arc or a spline as an edge in openfoam 1.5
mgz1985 is offline   Reply With Quote
Old   July 30, 2008, 10:06
Default Hi Mayanak, My sincere apol
Hi Mayanak,
My sincere apologies. It was a long time ago and I'm not sure if I remember what I did to overcome the problem. I do remember that this was something to do with a wrong definition in one of the dictionary files, not to do with any code. I'll try to look into my scrap notes and see if I can figure this out. Once again, very sorry.
FOAM FATAL IO ERROR attempt to read beyond EOF unoder OpenFOAM Running, Solving & CFD 10 April 16, 2024 03:03
[Commercial meshers] FOAM FATAL ERROR points deallocated hoerl OpenFOAM Meshing & Mesh Conversion 0 October 30, 2006 07:47
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 14:20
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 04:37
