Guidance on reading an error message
Old   January 24, 2008, 10:54
Default Dear OpenFOAM community, I
laurent25
I am playing with the icoDyMFoam solver. I looked at the tutorial and I am now trying to build a simple 2D case: a box with a lid on the top moving up and down.
When running it, I have the following error message:
laurent@laurent-desktop:~/OpenFOAM/laurent-1.4.1/run/test2D$ icoDyMFoam . estuary
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : icoDyMFoam . estuary
Date : Jan 24 2008
Time : 15:27:59
Host : laurent-desktop
PID : 9404
Root : /home/laurent/OpenFOAM/laurent-1.4.1/run/test2D
Case : estuary
Nprocs : 1
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: velocityComponentLaplacian
--> FOAM FATAL ERROR : Not implemented#0 Foam::error::printStack(Foam:stream&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::defaultFvPatchField<double>::defaultFvPatchF ield(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#3 Foam::fvPatchField<double>::addpatchConstructorToT able<foam::defaultfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam "
#5 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::List<foam::word> const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#6 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::fvMesh const&, Foam::dimensioned<double> const&, Foam::List<foam::word> const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#7 Foam::velocityComponentLaplacianFvMotionSolver::ve locityComponentLaplacianFvMoti onSolver(Foam::polyMesh const&, Foam::Istream&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#8 Foam::motionSolver::adddictionaryConstructorToTabl e<foam::velocitycomponentlapla cianfvmotionsolver>::New(Foam::polyMesh const&, Foam::Istream&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#9 Foam::motionSolver::New(Foam::polyMesh const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so"
#10 Foam::dynamicMotionSolverFvMesh::dynamicMotionSolv erFvMesh(Foam::IOobject const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#11 Foam::dynamicFvMesh::addIOobjectConstructorToTable <foam::dynamicmotionsolverfvme sh>::New(Foam::IOobject const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#12 Foam::dynamicFvMesh::New(Foam::IOobject const&) in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#13 main in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam "
#14 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#15 Foam::regIOobject::readIfModified() in "/home/laurent/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam "
From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch& p, const DimensionedField<type,>& iF)
in file fields/fvPatchFields/basic/default/defaultFvPatchField.C at line 50.
FOAM aborting
Aborted (core dumped)
Could someone give me some guidance on how to interpret this message?
thanks very much in advance
Laurent
Old   January 24, 2008, 11:16
Default The text after FOAM FATAL ERRO
Assistant Moderator
Bernhard Gschaider
The text after FOAM FATAL ERROR is a situation specific error message (in your case: the method exists, but is not properly implemented)
The stuff with #<nr> is a stack-trace (http://en.wikipedia.org/wiki/Stack_trace) (If you're using a Debug-version of OF it might even show you the files and line numbers)
After that follows the source-file and the line number that caused the error.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 16, 2008, 10:05
Default Do you recall what you changed
Scott Ford
saf5029 is on a distinguished road
Do you recall what you changed when you got this error, I just got an identical one and am having trouble fixing it.
Thanks
Scott
saf5029 is offline   Reply With Quote
Old   June 18, 2008, 07:32
Default hi, i am compiling a solver(m
davey david
suredross is on a distinguished road
hi,
i am compiling a solver(modified icoFoam)to solve this equation:
dimensionedScalar k=q*l/(U0*mu);
solve (
(Ux = -(k*fvc::grad(psi)))
//(like a boundary condition)
and keep getting this error:
SOURCE=jxnFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/cfd/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/cfd/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/jxnFoam.o
jxnFoam.C: In function 'int main(int, char**)':
jxnFoam.C:115: error: invalid use of void expression
/home/cfd/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/initContinuityErrs. H:38: warning: unused variable 'cumulativeContErr'
make: *** [Make/linuxGccDPOpt/jxnFoam.o] Error 1
any help will be appreciated.
cheers
davey
suredross is offline   Reply With Quote
Old   June 18, 2008, 07:47
Default Assume psi is a scalar, then g
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Assume psi is a scalar, then grad(psi) is a vector which cannot be equal to a scalar, which I assumme Ux is.
Further I believe you need '==' and not just '=' when setting up equations. Further no 'fvm::' command is used, thus no variable to solve for is specified.
I you want qualified help, you need to post definition of the different variables etc, otherwise you will receive guesses just as this on.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   June 18, 2008, 09:29
Default hi Niels good to hear from yo
davey david
hi Niels
good to hear from you again.
i am trying to impose a boundary condition(the Helmholtz-smoluchowski equation) on the walls of my case after the calculation for an electrical field has elapsed.this is to see the effect the field will have on the velocity at the cells next(immediately)to the boundary.
what will be the best way to go about this?any suggestions are welcome
regards
davey
Error when reading res file Taewon Seo CFX 1 April 28, 2009 09:09
error by reading cas and dat data! Hai Duc FLUENT 0 December 12, 2007 04:56
Error reading mesh Naghman Khan FLUENT 0 July 17, 2007 10:13
error reading file limingtiger Siemens 3 September 21, 2005 20:31
error reading xy data zago FLUENT 1 February 25, 2004 10:05
