August 22, 2007, 05:46 |
I am getting error message whi
kalaiselvan
Rep Power: 17 |
I am getting error message while running the already defined tutorial case file in sonicFoam. This happens for the case file "shockTube".
The following error message is shown: Foam::error::printStack(Foam:stream&) Foam::sigFpe::sigFpeHandler(int) [0xffffe420] Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) void Foam::divide<double,>(Foam::GeometricField<double, >&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) Foam::tmp<foam::geometricfield<double,> > Foam::operator/<double,>(Foam::tmp<foam::geometricfield<double, > > const&, Foam::tmp<foam::geometricfield<double,> > const&) sonicFoam [0x805b611] __libc_start_main __gxx_personality_v0 Can anyone sort out the problem and explain me the same. I am a beginner |
August 22, 2007, 05:51 |
Somewhere for some reason your
Hrvoje Jasak
Rep Power: 33 |
Somewhere for some reason your code is dividing by zero. Is your initial pressure or temperature field zero by any chance? Did you run initialisation for the case?
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 12, 2008, 06:57 |
You should run setShock first
Arun Shourie
Rep Power: 17 |
You should run setShock first to get the values of p,U and T updated....
then try for running the case file. It will definitely work |
Shock Tube problem | mouna lamnaouer | FLUENT | 1 | September 22, 2011 12:47 |
Sod Shock Tube problem | cfd | Main CFD Forum | 4 | July 7, 2009 13:24 |
SOD shock tube problem | Luuk | Main CFD Forum | 3 | September 6, 2005 05:08 |
Shock tube problem | AB | Siemens | 1 | November 9, 2004 00:25 |
Shock tube problem | ger | Main CFD Forum | 1 | September 24, 2003 07:41 |
