Fail to run when turn on Wll Contact Angle
Old   May 7, 2006, 18:38
Default Hi, I am wondering if anyon
Pei-Ying Hsieh
hsieh is on a distinguished road
I am wondering if anyone has the same error when trun on wall contact angle:
Exec : interFoam . damBreak
Date : May 07 2006
Time : 18:38:02
Host : linux
PID : 7709
Root : /home/phsieh/OpenFOAM/phsieh-1.3/run/tutorials/interFoam
Case : damBreak
Nprocs : 1
Create time
Create mesh
Selecting dynamicFvMesh staticFvMesh
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
--> FOAM FATAL ERROR : Not implemented
From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch& p, const Field<type>& iF)
in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 50.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
Foam::defaultFvPatchField<double>::defaultFvPatchF ield(Foam::fvPatch const&, Foam::Field<double> const&)
Foam::fvPatchField<double>::addpatchConstructorToT able<foam::defaultfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::Field<double> const&)
Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::Field<double> const&)
interFoam [0x467ff6]
interFoam [0x489bee]
interFoam [0x43ace5]
__libc_start_main
__gxx_personality_v0
Aborted
Pei
hsieh is offline   Reply With Quote
Old   May 8, 2006, 08:10
Default What is your gamma boundary ca
Eugene de Villiers
eugene is on a distinguished road
What is your gamma boundary called?
It should one of the following:
constantGammaContactAngle
dynamicGammaContactAngle
timeVaryingGammaContactAngle
check interFoam/interfaceProperties/gammaContactAngle
for details.
eugene is offline   Reply With Quote
Old   May 9, 2006, 10:09
Default Hi, Eugene, Thanks for the
Pei-Ying Hsieh
Hi, Eugene,
Thanks for the reply.
It works after I manually change from gammaContactAngle to constantGammaContactAngle.
However, if I use FoamX to set the case up, I only get "gammaContactAngle" - cannot specify whether it is constant or dynamic or timeVarying. Is it correct? Am I missing something when using FoamX? (this is not a problem in version 1.2).
Pei
Old   May 9, 2006, 10:55
Default Post this to the Bug forum.
Eugene de Villiers
Old   July 26, 2007, 04:39
Default Sorry to re-open this one but
Mark Dowling
markdowlinguk is on a distinguished road
Sorry to re-open this one but I have exactly the same problem, but I dont understand Eugene's answer to it.
I checked to find a file or directory called interFoam/interfaceProperties/gammaContactAngle (under applications/solvers/multiphase) but in my version (OpenFoam 1.4) I couldnt find anything there.
I tried changing "gammaContactAngle" to "constantGammaContactAngle" in the gamma file at time 0 - but that just produced another error because it didnt recognise the expression constantGammaContactAngle
If somebody could indulge a beginner like me and take me through what Pei did to get his case working I would be very grateful.
Many thanks
Mark
markdowlinguk is offline   Reply With Quote
Old   July 26, 2007, 08:00
Default Hi, Mark, Send me your emai
Pei-Ying Hsieh
Hi, Mark,
Send me your email address. I can send you a simple case file to see if you can run it without any problem.
Pei
phsieh2005@yahoo.com
Old   August 7, 2007, 08:25
Default Hi, Mark, Did you receive t
Pei-Ying Hsieh
Hi, Mark,
Did you receive the test case I sent you? Did that resolve your issue?
Pei
Old   October 17, 2007, 23:11
Default Hi, Pei-Ying Hsieh. I have th
Giro
girogirozakk is on a distinguished road
Hi, Pei-Ying Hsieh.
I have the same problem.
If are there no problem , I want sample-case file.....OK?
Giro
girogirozakk is offline   Reply With Quote
Old   May 21, 2008, 01:02
Default Hi, I have the same probl
zhiwei liu
lzw2003 is on a distinguished road
I have the same problem.And i still can't solve it.I hope anyyone who did out can tell me.
But i don't think it is a bug. In the dynamicGammaContactAngleFvPatchField.C,it said :
if "utheta" < SMALL {return Theta0}.
I think in this time , it uses the constantgammacontactAngle model
. else using the dynamicgammacontactAngle model !
lzw2003 is offline   Reply With Quote
contact angle yan FLUENT 4 November 6, 2012 04:22
Contact angle UDF shephali shrimali FLUENT 0 May 10, 2007 07:52
About the Contact Angle Flora FLUENT 2 March 8, 2007 02:07
Moving contact line (dynamic contact angle) Pulli FLUENT 0 March 1, 2007 12:31
how to set contact angle njtu FLUENT 0 August 26, 2005 12:47
