Power Law Viscosity Model
Old   February 12, 2008, 22:10
Default Hi, I tried to use Power La
J. T.
cpplabs is on a distinguished road
I tried to use Power Law model by modifying Cross Power Law model. The following is the function I tried:
tmp<volscalarfield> PowerLaw::calcNu() const
return m_ * pow(0.01 + strainRate(), n_ - 1.0);
The function is ok to compile and link. But, when I tried to run the program, a fatal error happens in the following operator function:
dimensionSet operator+(const dimensionSet& ds1, const dimensionSet& ds2)
dimensionSet dimSum(ds1);
if (dimensionSet::debug && ds1 != ds2)
FatalErrorIn
("operator+(const dimensionSet& ds1, const dimensionSet& ds2)")
<< "LHS and RHS of + have different dimensions" << endl
<< " dimensions : " << ds1 << " + " << ds2 << endl
<< abort(FatalError);
return dimSum;
It seems that the summation between the scalar value 0.01 and the strain rate scalar field is not allowed.
Can someone tell me the reason of the problem and how to fix the problem?
Thanks in advance.
cpplabs is offline   Reply With Quote
Old   February 13, 2008, 08:09
Default Hi Dragos, Thanks for the
J. T.
Hi Dragos,
Thanks for the tip. It is dimension problem, the method can pass the dimension check but it causes problem in the returned volScalarField: the dimension of returned volScaleField changes with the parameter n.
The right way is to do the following:
return nu0_ * pow(0.01 + m_ * strainRate(), n_ - 1.0);
The m_ has reversed dimension with the return of strainRate() so that the product is dimentionless.
Non-Newtonian Power Law for Viscosity John FLUENT 16 September 12, 2015 06:18
new parameter for non newtonian power law model! Antoine FLUENT 0 July 21, 2008 04:30
Non newtonian power law model in pipe annulus Poly FLUENT 0 March 24, 2005 15:12
Power law model for porous media Karl FLUENT 0 December 13, 2004 15:14
Viscosity - power law HOC Main CFD Forum 1 January 15, 2003 15:17
