Export patch profile
Old   January 17, 2008, 04:50
Default How can I export a variable pr
John Deas
johndeas is on a distinguished road
How can I export a variable profile on a boundary patch ?
johndeas is offline   Reply With Quote
Old   January 22, 2008, 07:45
Default More precisely, how can I expo
John Deas
More precisely, how can I export the content of a fvPatchField (either <double> or vector<double>) to a file ?
Old   January 23, 2008, 06:54
Default To better understand how class
John Deas
To better understand how classes work, I tried to play a little. What I do not understand is why this code :
List<scalar> a(10);
a=2;
List<scalar> b(10);
b=3;
List<scalar> c=a+b;
Info << "c(1) = " << c[1] << endl;
gives the result c(1) = 5
since in the member functions of List I can not find the operator +
Old   January 23, 2008, 07:30
Default Not sure what else you have ex
Hrvoje Jasak
Not sure what else you have expected: 2 + 3 = 5.
Here, you created 2 lists of size 10, then assigned all elements of first list to 2 and all elements of the second list to 3 and summed them up.
The actual operator+(...) you are using is:
template<class>
tmp<field<typename>::type> >
operator Op(const UList<type1>& f1, const UList<type2>& f2);
in
/home/hjasak/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/fields/Fields/Field/FieldF unctions.H
Beware of the macros...
Hrv
Hrvoje Jasak
Old   January 25, 2008, 04:17
Default Why are some operators impleme
John Deas
Why are some operators implemented via member functions and others via macros ? It seems to me that macros are harder to find in the documentation ?
Old   January 25, 2008, 04:27
Default Because of code re-use and con
Hrvoje Jasak
Because of code re-use and consistency. Templates, (of course, you mean templates! rather than member functions) are preferred whenever possible - in fact you will see that the macro I've showed you actually defines a template.
Other possible question you may be asking is why is eg. operator+= a member and operator+ a friend. There are VERY good reasons for it, to do with automatic type conversion on the rhs argument. A good C++ book will tell you why.
Enjoy,
Hrv
Hrvoje Jasak
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH mkraposhin OpenFOAM Running, Solving & CFD 3 September 4, 2011 09:42
SampleDict patch export surface size amp orientation axel OpenFOAM Post-Processing 1 September 29, 2008 13:42
Patch mesh export ariorus OpenFOAM 3 March 7, 2006 05:41
about patch ZQX FLUENT 1 October 14, 2005 04:54
Boundary profile export each iteration Jiri Novak FLUENT 2 July 27, 2005 03:19
