Is it to possible to change time step DeltaT during a calculation
Like Tree7Likes
  • 1 Post By dbxmcf
  • 1 Post By dbxmcf
  • 3 Post By philippose
  • 2 Post By parthiv1991
Old   March 12, 2007, 23:44
Default I am using icoFoam to calculat
roy fokker
dbxmcf is on a distinguished road
I am using icoFoam to calculate a simple fluid, however I want to change the time step dynamically, e.g. first time step is: deltaT[1]=0.001, the next time step is deltaT[2]=0.003, the next is deltaT[3]=0.002, and so on.
i.e.
t0=0
t1=0+0.001=0.001
t2=0.001+0.003=0.004
t3=0.004+0.002=0.006
Maybe it is a wired problem, but in my program it seems that I need such kind of dynamic timestep, is it possible to program it in OpenFOAM? I didn't find any function like runTime.setTimeStep(DeltaT)...the only function I found is adjustDeltaT() but it is protected and after I read through the source, I found it is not doing what I want.
Thanks a lot!
sunshuai likes this.
dbxmcf is offline   Reply With Quote
Old   March 13, 2007, 02:32
Default I use scalar dt=runTime.de
Thomas Jung
tehache is on a distinguished road
I use
scalar dt=runTime.deltaT()
to get the actual timestep, and
runTime.setDeltaT(dt)
to set it to a new value, works.
Have fun ...
Thomas
tehache is offline   Reply With Quote
Old   November 1, 2007, 17:59
Default Hi. the example above, is e
Ken Darcovich
kdarc is on a distinguished road
Hi.
the example above, is exactly what I'm trying to do and when I implement the code as shown above, NOTHING changes.
This makes me think that I also have to have some "include file" statements, or need to have some extra libraries mentioned in the "options" file.
Any advice?
thanks.
kdarc is offline   Reply With Quote
Old   November 1, 2007, 18:48
Default it should work using setDeltaT
roy fokker
it should work using setDeltaT(dt):
like this:
runTime.setTime(tStart,0);
runTime.setDeltaT(dt);
runTime.setEndTime(runTime.value()+runTime.deltaT( ).value());
Saleh Mey likes this.
Old   November 4, 2007, 14:21
Default Hello, A Good day to you!
Philippose Rajan
philippose will become famous soon enough
A Good day to you!
Sorry I could not get into this post a little earlier... I saw the post, but was away, so could not react to it :-)!
Some time back, I had modified the icoFoam solver to include variable time step functionality as a question from another user on this forum.
Unfortunately, I am unable to find that post now... so... here is "icoFoamVarDt"... basically does exactly what you want..... it uses the built in capability in OpenFOAM to limit the Courant Number by adapting the time step size....
Hope this helps....
icoFoamVarDt.tar.gz
In order to activate this, you need to use the "adjustTimeStep yes" option, followed my "maxCo [maximum Co Number you want to limit to]" in the controlDict file.
Philippose
solefire, saba_saeb and manju819 like this.
philippose is offline   Reply With Quote
Old   January 26, 2018, 16:03
Default Adjustable Time-Step
PLD
parthiv1991 is on a distinguished road
Hello Everyone,
I am trying to implement an adaptive time-stepping scheme based on the error. So for example, a rough code would look like this:
if  error > tolerance
    //compute new deltaT and set new deltaT;
    //and Reject this step, and re-compute the same step with a new deltaT = dt;
Do anyone of you know how to implement this rejecting a particular step and re-computing the values again in the same step but using a new deltaT ??
I can successfully set the new time-step, but cannot recompute the same step using the new deltaT. I tried runTime--, and also runTime.Times = runTime.times - oldDeltaT; but nothing works.
Even the "adjustTimeStep" is set to "true" in controlDict.
Any help would be appreciated.
Thank you in advance.
cfdlance.com and dats like this.
parthiv1991 is offline   Reply With Quote
time step calculation david FLUENT 1 May 7, 2008 01:36
unsteady state calculation with adaptive time step sm FLUENT 0 November 7, 2007 01:26
How to change boundary type at calculation time? Stanislav Kraev FLUENT 0 December 4, 2006 03:33
time step calculation in unsteady solidconduction ps Siemens 0 July 19, 2006 01:01
Time step calculation Shashi Main CFD Forum 1 March 1, 2006 07:27
