Modified boundaries for InterFoam
Old   February 22, 2006, 00:32
Default Hello friends I am using th
kumar
kumar2 is on a distinguished road
Hello friends
I am using the InterFoam solver to look at flow over a bump. this is a popular example from hydraulics. But i have to modify all the boundaries. For example at the inlet , the gamma is 1 below the free surface and 0 above it. similarly at the outlet the pressure is 0 above the free surface and varies linearly below it.
although both the inlet and outlet are fixedValue types how can we give a variable say gamma or pressure changing across the boundary.
ideally this should be through a small subroutine ( that is how this was implemented in Comet) . In all the tutorials the fixedValue are uniform . But how can we give a function there ??
Thanks in advance.
kumar
kumar2 is offline   Reply With Quote
Old   February 23, 2006, 22:31
Default Can anybody please give some i
kumar
Can anybody please give some inputs for this problem
thanks
kumar
Old   February 24, 2006, 02:28
Default Hi kumar, This question has
Jens Klostermann
jens_klostermann is on a distinguished road
Hi kumar,
This question has been asked many times, just search for nonuniform in the forum.
I did for example like in http://www.cfd-online.com/OpenFOAM_D...es/1/1118.html
Regards
Jens
jens_klostermann is offline   Reply With Quote
Old   February 24, 2006, 03:48
Default Kumar, I would suggest to spe
Michele
michele is on a distinguished road
Kumar,
I would suggest to specify two inlet patches directly inside the mesh: the first with gamma = 0 and the second with gamma = 1.
Be careful that in the interFoam solver the pressure variable is the "modified pressure pd". An hydrostatic distribution is represented by a constant "pd".
Regards,
Michele.
michele is offline   Reply With Quote
Old   March 2, 2006, 04:30
Default Hi Michele 1. Thanks a lo
kumar
Hi Michele
1.
Thanks a lot for your e-mail. But i am really confused with the modified pressure . for example in the interFoam tutorial on breaking dams , when i looked for boundary values for pd in /damBreak/0/pd file . i was surprised to find that p0 is specified. First question is how is pressure modified (pd) calculated from p0
2. If for example there is a channel about 0.3 m deep with water level say at 0.15m , and water velocity is 0.8 m/s . Then the total pressure would be the hydrostatic pressure(rho*g*h) + hydrodymanic pressure(1/2 *rho*V^2 ). The units of the total pressure would be KG /M/S^2 . If as you say the hydrostatic pressure is constant then isn't there a division by 'h' . but in that case the units would be different from [1 -1 -2 0 0 0]. Could you please tell me the p0 and p modified at the free surface and bottom of the channel.
Old   August 16, 2007, 03:27
Default Can anyone provide some more i
paka is on a distinguished road
Can anyone provide some more input about "modified pressure"?
I'm using rasInterFoam solver with dam break problem. Looking at present results, I assume the same "modified pressure" exists in my case.
When I view the pressure at one of initial times (i.e. 0.04s) the pressure is constant along whole height, which one would expect to be hydrostatic and it isn't.
Can anyone provide some input, how to obtain the total REAL pressure values during whole run?
Kumar? How did you deal with that?
Thanks and best regards,
Krystian
paka is offline   Reply With Quote
Cyclic boundaries importing Gambit msh file and interFoam chegdan OpenFOAM Running, Solving & CFD 16 February 14, 2023 03:56
Modified twoPhaseEulerFoam alberto OpenFOAM Running, Solving & CFD 19 March 14, 2012 06:10
Modified reconstructPar jens_klostermann OpenFOAM Post-Processing 1 March 29, 2007 14:34
Modified twoPhaseEulerFoam alberto OpenFOAM Running, Solving & CFD 1 November 7, 2006 07:09
ENO without ROE MODIFIED duanyee Main CFD Forum 0 January 27, 2002 09:48
