July 25, 2006, 20:43 |
I'm trying the same cav
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
I'm trying the same cavity case as explained in the user guide. But I've increased the mesh to 10000 cells and decreased the time step from 0.005 to 0.001. The case runs happily when in serial mode. When I decompose the domain and run in parallel, it seems to run fine for a while after which, suddenly a solution singluarity appears. The BCs and problem definition are OK as the case runs properly in serial. Any suggestions (please look at the time between 0.013 and 0.015 seconds). Thanks for your help. PS: At Time = 0.024, I hit Ctrl + C. Also, when running the case in parallel again (from scratch) sometimes it works fine up to 0.2 or 0.3 seconds, sometimes less, sometimes it just hangs there with no error messages as if waiting for something. Has anybody experienced such random behavior. I'm using OpenFOAM on a 64 bit IBM p360 (4-CPU) machine running Suse Linux 10.1 and lam (compiled from sources that came with OpenFOAM). madhavan@varese:~/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam> ls Allclean cavity cavityGrade cavity_large_mesh_backup machines Allrun cavityClipped cavity_large_mesh elbow resetFixedWallsScr madhavan@varese:~/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam> decomposePar . cavity_large_mesh /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : decomposePar . cavity_large_mesh Date : Jul 25 2006 Time : 19:20:21 Host : varese PID : 32389 Root : /home/madhavan/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam Case : cavity_large_mesh Nprocs : 1 Create time Time = 0 Create mesh Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 0.45 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Calculating processor boundary addressing Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 2500 Number of faces shared with processor 1 = 50 Number of faces shared with processor 2 = 50 Number of boundary faces = 5100 Processor 1 Number of cells = 2500 Number of faces shared with processor 0 = 50 Number of faces shared with processor 3 = 50 Number of boundary faces = 5100 Processor 2 Number of cells = 2500 Number of faces shared with processor 0 = 50 Number of faces shared with processor 3 = 50 Number of boundary faces = 5100 Processor 3 Number of cells = 2500 Number of faces shared with processor 1 = 50 Number of faces shared with processor 2 = 50 Number of boundary faces = 5100 Processor 0: field transfer Processor 1: field transfer Processor 2: field transfer Processor 3: field transfer End. madhavan@varese:~/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam> mpirun -np 4 icoFoam . cavity_large_mesh -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : icoFoam . cavity_large_mesh -parallel Exec : icoFoam . cavity_large_mesh -parallel Exec : icoFoam . cavity_large_mesh -parallel Exec : icoFoam . cavity_large_mesh -parallel [2] Date : Jul 25 2006 [2] Time : 19:21:14 [0] Date : Jul 25 2006 [0] Time : 19:21:14 [0] Host : varese [2] Host : varese [2] PID : 32393 [3] Date : Jul 25 2006 [3] Time : 19:21:14 [0] PID : 32391 [3] Host : varese [3] PID : 32394 [1] Date : Jul 25 2006 [1] Time : 19:21:14 [1] Host : varese [1] PID : 32392 [1] Root : /home/madhavan/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam [1] Case : cavity_large_mesh [1] Nprocs : 4 [2] Root : /home/madhavan/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam [2] Case : cavity_large_mesh [2] Nprocs : 4 [3] Root : /home/madhavan/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam [3] Case : cavity_large_mesh [0] Root : /home/madhavan/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam [0] Case : cavity_large_mesh [0] Nprocs : 4 [0] Slaves : [0] 3 [3] Nprocs : 4 [0] ( [0] varese.32392 [0] varese.32393 [0] varese.32394 [0] ) [0] Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.001 Mean and max Courant Numbers = 0 0 BICCG: Solving for Ux, Initial residual = 1, Final residual = 9.04991e-06, No Iterations 18 BICCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 ICCG: Solving for p, Initial residual = 1, Final residual = 6.86206e-07, No Iterations 201 time step continuity errors : sum local = 4.28884e-10, global = -9.48776e-21, cumulative = -9.48776e-21 ICCG: Solving for p, Initial residual = 0.672536, Final residual = 8.34589e-07, No Iterations 200 time step continuity errors : sum local = 7.54547e-10, global = -5.38652e-20, cumulative = -6.3353e-20 ExecutionTime = 2.51 s ClockTime = 3 s Time = 0.002 Mean and max Courant Numbers = 0.0296832 0.810069 BICCG: Solving for Ux, Initial residual = 0.119078, Final residual = 6.90333e-06, No Iterations 17 BICCG: Solving for Uy, Initial residual = 0.386927, Final residual = 6.9427e-06, No Iterations 18 ICCG: Solving for p, Initial residual = 0.722155, Final residual = 9.66376e-07, No Iterations 198 time step continuity errors : sum local = 9.31977e-10, global = -1.34216e-19, cumulative = -1.97569e-19 ICCG: Solving for p, Initial residual = 0.633029, Final residual = 9.07363e-07, No Iterations 197 time step continuity errors : sum local = 9.3323e-10, global = 1.01922e-19, cumulative = -9.56466e-20 ExecutionTime = 4.04 s ClockTime = 4 s Time = 0.003 Mean and max Courant Numbers = 0.0449432 0.926016 BICCG: Solving for Ux, Initial residual = 0.047979, Final residual = 9.80318e-06, No Iterations 15 BICCG: Solving for Uy, Initial residual = 0.146506, Final residual = 4.93936e-06, No Iterations 17 ICCG: Solving for p, Initial residual = 0.711663, Final residual = 9.89994e-07, No Iterations 197 time step continuity errors : sum local = 7.55206e-10, global = 4.25957e-20, cumulative = -5.30509e-20 ICCG: Solving for p, Initial residual = 0.663622, Final residual = 8.84782e-07, No Iterations 197 time step continuity errors : sum local = 6.7351e-10, global = 8.68074e-21, cumulative = -4.43702e-20 ExecutionTime = 5.55 s ClockTime = 6 s Time = 0.004 Mean and max Courant Numbers = 0.053069 0.930456 BICCG: Solving for Ux, Initial residual = 0.026967, Final residual = 8.26492e-06, No Iterations 14 BICCG: Solving for Uy, Initial residual = 0.104978, Final residual = 5.43694e-06, No Iterations 16 ICCG: Solving for p, Initial residual = 0.496791, Final residual = 9.2743e-07, No Iterations 196 time step continuity errors : sum local = 5.71826e-10, global = -6.46623e-22, cumulative = -4.50168e-20 ICCG: Solving for p, Initial residual = 0.45407, Final residual = 8.34512e-07, No Iterations 196 time step continuity errors : sum local = 5.17042e-10, global = 1.43151e-19, cumulative = 9.81339e-20 ExecutionTime = 7.07 s ClockTime = 7 s Time = 0.005 Mean and max Courant Numbers = 0.0597545 0.939777 BICCG: Solving for Ux, Initial residual = 0.0206086, Final residual = 5.9467e-06, No Iterations 14 BICCG: Solving for Uy, Initial residual = 0.0574585, Final residual = 8.81759e-06, No Iterations 14 ICCG: Solving for p, Initial residual = 0.41837, Final residual = 7.66076e-07, No Iterations 195 time step continuity errors : sum local = 3.66536e-10, global = 1.93771e-19, cumulative = 2.91905e-19 ICCG: Solving for p, Initial residual = 0.38174, Final residual = 8.99953e-07, No Iterations 194 time step continuity errors : sum local = 4.33183e-10, global = -1.20382e-19, cumulative = 1.71523e-19 ExecutionTime = 8.55 s ClockTime = 9 s Time = 0.006 Mean and max Courant Numbers = 0.0648963 0.946156 BICCG: Solving for Ux, Initial residual = 0.0139187, Final residual = 7.52264e-06, No Iterations 13 BICCG: Solving for Uy, Initial residual = 0.0455918, Final residual = 7.22159e-06, No Iterations 14 ICCG: Solving for p, Initial residual = 0.253609, Final residual = 8.96376e-07, No Iterations 192 time step continuity errors : sum local = 3.92679e-10, global = 5.5118e-20, cumulative = 2.26641e-19 ICCG: Solving for p, Initial residual = 0.229742, Final residual = 8.75365e-07, No Iterations 192 time step continuity errors : sum local = 3.8378e-10, global = -8.76987e-20, cumulative = 1.38943e-19 ExecutionTime = 10.02 s ClockTime = 10 s Time = 0.007 Mean and max Courant Numbers = 0.0692539 0.949465 BICCG: Solving for Ux, Initial residual = 0.0116939, Final residual = 6.09785e-06, No Iterations 13 BICCG: Solving for Uy, Initial residual = 0.0320625, Final residual = 7.43667e-06, No Iterations 13 ICCG: Solving for p, Initial residual = 0.180605, Final residual = 9.52495e-07, No Iterations 189 time step continuity errors : sum local = 3.83623e-10, global = -1.58405e-19, cumulative = -1.94624e-20 ICCG: Solving for p, Initial residual = 0.163707, Final residual = 9.64875e-07, No Iterations 188 time step continuity errors : sum local = 3.90012e-10, global = -7.23862e-20, cumulative = -9.18486e-20 ExecutionTime = 11.47 s ClockTime = 12 s Time = 0.008 Mean and max Courant Numbers = 0.0729413 0.952808 BICCG: Solving for Ux, Initial residual = 0.00909364, Final residual = 8.65935e-06, No Iterations 12 BICCG: Solving for Uy, Initial residual = 0.0269566, Final residual = 6.7032e-06, No Iterations 13 ICCG: Solving for p, Initial residual = 0.109123, Final residual = 8.15401e-07, No Iterations 188 time step continuity errors : sum local = 3.10857e-10, global = 1.21822e-20, cumulative = -7.96664e-20 ICCG: Solving for p, Initial residual = 0.0988474, Final residual = 9.23239e-07, No Iterations 187 time step continuity errors : sum local = 3.52258e-10, global = 1.454e-19, cumulative = 6.57332e-20 ExecutionTime = 12.91 s ClockTime = 13 s Time = 0.009 Mean and max Courant Numbers = 0.0761604 0.954918 BICCG: Solving for Ux, Initial residual = 0.00788061, Final residual = 8.02051e-06, No Iterations 12 BICCG: Solving for Uy, Initial residual = 0.0216089, Final residual = 7.38888e-06, No Iterations 12 ICCG: Solving for p, Initial residual = 0.0751862, Final residual = 8.52566e-07, No Iterations 184 time step continuity errors : sum local = 3.22218e-10, global = -2.50286e-19, cumulative = -1.84553e-19 ICCG: Solving for p, Initial residual = 0.0683289, Final residual = 8.71176e-07, No Iterations 184 time step continuity errors : sum local = 3.2978e-10, global = 2.72231e-20, cumulative = -1.5733e-19 ExecutionTime = 14.32 s ClockTime = 14 s Time = 0.01 Mean and max Courant Numbers = 0.078984 0.956873 BICCG: Solving for Ux, Initial residual = 0.00663957, Final residual = 5.93408e-06, No Iterations 12 BICCG: Solving for Uy, Initial residual = 0.0188549, Final residual = 6.51374e-06, No Iterations 12 ICCG: Solving for p, Initial residual = 0.0476218, Final residual = 7.87959e-07, No Iterations 183 time step continuity errors : sum local = 2.92796e-10, global = -3.27487e-20, cumulative = -1.90078e-19 ICCG: Solving for p, Initial residual = 0.0435532, Final residual = 8.46472e-07, No Iterations 182 time step continuity errors : sum local = 3.1477e-10, global = 9.94609e-20, cumulative = -9.06174e-20 ExecutionTime = 15.72 s ClockTime = 16 s Time = 0.011 Mean and max Courant Numbers = 0.0815052 0.958373 BICCG: Solving for Ux, Initial residual = 0.00586825, Final residual = 9.88343e-06, No Iterations 11 BICCG: Solving for Uy, Initial residual = 0.0161717, Final residual = 9.9482e-06, No Iterations 11 ICCG: Solving for p, Initial residual = 0.0356458, Final residual = 9.13337e-07, No Iterations 182 time step continuity errors : sum local = 3.37795e-10, global = -2.71539e-19, cumulative = -3.62156e-19 ICCG: Solving for p, Initial residual = 0.0329001, Final residual = 7.4762e-07, No Iterations 182 time step continuity errors : sum local = 2.7672e-10, global = -1.66423e-19, cumulative = -5.28579e-19 ExecutionTime = 17.13 s ClockTime = 17 s Time = 0.012 Mean and max Courant Numbers = 0.0837613 0.959674 BICCG: Solving for Ux, Initial residual = 0.00515329, Final residual = 8.0906e-06, No Iterations 11 BICCG: Solving for Uy, Initial residual = 0.0144256, Final residual = 7.93775e-06, No Iterations 11 ICCG: Solving for p, Initial residual = 0.0248828, Final residual = 8.89308e-07, No Iterations 179 time step continuity errors : sum local = 3.28367e-10, global = -6.074e-20, cumulative = -5.89319e-19 ICCG: Solving for p, Initial residual = 0.0232373, Final residual = 9.85799e-07, No Iterations 178 time step continuity errors : sum local = 3.64155e-10, global = 1.95186e-19, cumulative = -3.94132e-19 ExecutionTime = 18.5 s ClockTime = 19 s Time = 0.013 Mean and max Courant Numbers = 0.0858044 0.960774 BICCG: Solving for Ux, Initial residual = 0.00462194, Final residual = 7.26935e-06, No Iterations 11 BICCG: Solving for Uy, Initial residual = 0.012806, Final residual = 7.36052e-06, No Iterations 11 ICCG: Solving for p, Initial residual = 0.0208117, Final residual = 8.85416e-07, No Iterations 179 time step continuity errors : sum local = 3.25548e-10, global = 9.66412e-20, cumulative = -2.97491e-19 ICCG: Solving for p, Initial residual = 0.0196253, Final residual = 8.99491e-07, No Iterations 179 time step continuity errors : sum local = 3.30787e-10, global = -7.37018e-21, cumulative = -3.04861e-19 ExecutionTime = 19.88 s ClockTime = 20 s Time = 0.014 Mean and max Courant Numbers = 0.0876578 0.961719 BICCG: Solving for Ux, Initial residual = 0.00415071, Final residual = 6.38942e-06, No Iterations 11 BICCG: Solving for Uy, Initial residual = 0.0115789, Final residual = 1.44374e+95, No Iterations 1001 ICCG: Solving for p, Initial residual = 1, Final residual = 9.6264e-07, No Iterations 189 time step continuity errors : sum local = 1.29818e+87, global = 5.93881e+76, cumulative = 5.93881e+76 ICCG: Solving for p, Initial residual = 0.934444, Final residual = 9.29122e-07, No Iterations 189 time step continuity errors : sum local = 1.32389e+87, global = 5.63113e+75, cumulative = 6.50193e+76 ExecutionTime = 25.46 s ClockTime = 26 s Time = 0.015 Mean and max Courant Numbers = 7.04549e+93 3.68526e+94 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p, Initial residual = 1, Final residual = 1.40439, No Iterations 5001 time step continuity errors : sum local = 1.88237e+101, global = 1.44676e+86, cumulative = 1.44676e+86 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 3.57117e+109, global = -6.875e+92, cumulative = -6.87499e+92 ExecutionTime = 39.12 s ClockTime = 39 s Time = 0.016 Mean and max Courant Numbers = 1.45147e+109 1.83744e+112 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.67439e+110, global = 2.48722e+94, cumulative = 2.41847e+94 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.26382e+111, global = -1.14441e+95, cumulative = -9.0256e+94 ExecutionTime = 39.47 s ClockTime = 40 s Time = 0.017 Mean and max Courant Numbers = 7.14503e+110 8.90101e+113 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 4.72906e+112, global = -1.80693e+96, cumulative = -1.89719e+96 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 2.80161e+113, global = 7.47804e+96, cumulative = 5.58085e+96 ExecutionTime = 39.82 s ClockTime = 40 s Time = 0.018 Mean and max Courant Numbers = 1.77155e+113 4.14651e+116 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 6.67211e+114, global = 1.87091e+99, cumulative = 1.87649e+99 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 2.64446e+115, global = 5.34057e+99, cumulative = 7.21706e+99 ExecutionTime = 40.16 s ClockTime = 40 s Time = 0.019 Mean and max Courant Numbers = 1.73067e+115 2.43263e+118 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.03355e+116, global = -2.80081e+99, cumulative = 4.41625e+99 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 8.83257e+116, global = 6.15057e+100, cumulative = 6.5922e+100 ExecutionTime = 40.51 s ClockTime = 41 s Time = 0.02 Mean and max Courant Numbers = 5.19846e+116 7.38682e+119 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 3.63936e+117, global = 3.23517e+101, cumulative = 3.89439e+101 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 8.63794e+118, global = 5.14892e+102, cumulative = 5.53836e+102 ExecutionTime = 40.85 s ClockTime = 41 s Time = 0.021 Mean and max Courant Numbers = 4.54631e+118 1.97763e+122 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 2.1432e+120, global = 1.32031e+104, cumulative = 1.3757e+104 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 4.05285e+121, global = 1.8166e+105, cumulative = 1.95417e+105 ExecutionTime = 41.2 s ClockTime = 41 s Time = 0.022 Mean and max Courant Numbers = 2.11858e+121 8.97658e+124 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.7996e+122, global = 8.53168e+105, cumulative = 1.04858e+106 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 2.79712e+124, global = -1.02687e+108, cumulative = -1.01639e+108 ExecutionTime = 41.55 s ClockTime = 42 s Time = 0.023 Mean and max Courant Numbers = 1.43656e+124 8.42775e+127 BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.90088e+125, global = -4.21083e+109, cumulative = -4.31247e+109 ICCG: Solving for p: solution singularity time step continuity errors : sum local = 1.54769e+126, global = -6.58994e+109, cumulative = -1.09024e+110 ExecutionTime = 41.89 s ClockTime = 42 s Time = 0.024 Mean and max Courant Numbers = 1.07014e+126 1.86495e+129 ----------------------------------------------------------------------------- One of the processes started by mpirun has exited with a nonzero exit code. This typically indicates that the process finished in error. If your process did not finish in error, be sure to include a "return 0" or "exit(0)" in your C code before exiting the application. PID 32391 failed on node n0 (127.0.0.1) due to signal 15. ----------------------------------------------------------------------------- madhavan@varese:~/OpenFOAM/madhavan-1.3/run/tutorials/icoFoam> |
July 26, 2006, 13:09 |
Ok, I think I've solved the pr
Rep Power: 21 |
Ok, I think I've solved the problem. Earlier, I used the following command to run icoFoam in parallel:
mpirun -np 4 icoFoam . cavity_large_mesh_parallel -parallel and I faced those random problems... Now, I use the command below to run icoFoam in parallel: mpirun -ssi rpi lamd C icoFoam . cavity_large_mesh_parallel -parallel and it seems to run without problems. Note that I did not have to specify '-np 4'. Apparently lamd and the kernel (linux) take care of spawning 4 processes as discussed here[1]. In both cases, I first do a lamboot -v machines The machines file (again in both cases) contains: localhost cpu=4 [1] http://www.lam-mpi.org/MailArchives/...01/04/2457.php |
July 27, 2006, 04:36 |
Can you make it crash repeated
Eugene de Villiers
Rep Power: 21 |
Can you make it crash repeatedly and consistently when using the old command?
July 27, 2006, 13:13 |
If 10 times can represent "rep
Rep Power: 21 |
If 10 times can represent "repeatedly", then yes. However, the crashes occur far apart in time steps. So with the old command, I could crash at the very beginning or even just before the last few time steps. Like I said, it appears random. Out of curiosity, why is that important? Thanks!
July 28, 2006, 03:30 |
If the occurrance is random, i
Eugene de Villiers
Rep Power: 21 |
If the occurrance is random, it is likely that the problem is with your hardware/drivers (or very unlikely in your case an uninitialised pointer object). If it occurs consistently it is more likely a problem with Foam or your setup.
I have run many cases on 8cpu shared memory opterons using the "mpirun -np 8" command without problems, so I doubt it is a Foam issue. |
July 28, 2006, 14:21 |
Thanks Eugene. Like I said the
Rep Power: 21 |
Thanks Eugene. Like I said the thing works fine if I use:
mpirun -ssi rpi lamd C icoFoam . cavity_large_mesh_parallel -parallel |
July 19, 2007, 06:02 |
FYI: I have discovered a bette
Rep Power: 21 |
FYI: I have discovered a better rpi for shared memory that works without any problems:
mpirun C -ssi rpi usysv icoFoam_1 . unsteady_validation_refined -parallel > unsteady_validation_refined/log 2>&1 & |
July 21, 2007, 04:58 |
Update: On this ppc64 system,
Rep Power: 21 |
Update: On this ppc64 system, although LAM 7.1.3 compiles fine, the MPI process randomly fails at different time steps even if I choose a different RPI like usysv (basically the same problem as described in the beginning). An MPICH build fails with the following error message:
gcc -m64 -o serv_p4 serv_p4.o server_ssl.o -lcrypt bin/mpicc -o /home/madhavan/OpenFOAM/OpenFOAM-1.4/src/mpich-1.2.7p1/bin/mpichversion /home/madhavan/ OpenFOAM/OpenFOAM-1.4/src/mpich-1.2.7p1/util/mpichversion.c /home/madhavan/OpenFOAM/OpenFOAM-1.4/src/mpich-1.2.7p1/util/mpichversion.c: In function âmainâ: /home/madhavan/OpenFOAM/OpenFOAM-1.4/src/mpich-1.2.7p1/util/mpichversion.c:67: warning: incompatible implicit declaration of built-in function âexitâ collect2: ld terminated with signal 11 [Segmentation fault] /usr/bin/ld: warning: powerpc:common architecture of input file `mpichversion.o' is incompatible wit h powerpc:common64 output mpichversion.o: In function `main': mpichversion.c.text+0xe0): relocation truncated to fit: R_PPC_REL24 against `strcmp' mpichversion.c.text+0x124): relocation truncated to fit: R_PPC_REL24 against `strcmp' mpichversion.c.text+0x168): relocation truncated to fit: R_PPC_REL24 against `strcmp' mpichversion.c.text+0x1ac): relocation truncated to fit: R_PPC_REL24 against `strcmp' mpichversion.c.text+0x1f0): relocation truncated to fit: R_PPC_REL24 against `strcmp' make[1]: *** [mpi-utils] Error 1 make: *** [mpi] Error 2 Luckily, OpenMPI 1.2.3 was built successfully and I am testing it now. |
July 21, 2007, 05:22 |
I do not know if your problem
I do not know if your problem is the same as mine, but, in my case , on a ppc64 - 128 node machine i had compiled lam and openFoam and I was facing a very similar problem, that the run used to stop randomly. I was able to solve the problem by compiling openFoam with the mpich libraries which i found already existing on the system.
I really don't know why it used to stop, but the above solved the problem completely. |
July 22, 2007, 02:58 |
Thanks for sharing your experi
Rep Power: 21 |
Thanks for sharing your experience. It appears that using OpenMPI 1.2.3 has solved this problem for good. By the way I easily get 2X speedup when using two processors. IBM sure did a nice job with their dual-cores
IcoFoam in parallel Issue with speed up | hjasak | OpenFOAM Running, Solving & CFD | 19 | October 11, 2011 17:07 |
Density in icoFoam Densidad en icoFoam | manuel | OpenFOAM Running, Solving & CFD | 8 | September 22, 2010 04:10 |
OF141dev installation Woes | chegdan | OpenFOAM Installation | 13 | July 18, 2008 17:16 |
Problem with IcoFoam in parallel | skabilan | OpenFOAM Running, Solving & CFD | 12 | April 1, 2008 05:55 |
SimpleFoam woes | msrinath80 | OpenFOAM Bugs | 2 | April 13, 2007 10:15 |
