Modeling shaking motion Vs Rotational motion
Old   July 17, 2007, 15:02
Default Dear OpenFoam users While s
jaswi is on a distinguished road
Dear OpenFoam users
While searching for the rotational motion of single frame I have found enough support and explanation. For the rotation one adds terms corresponding to the Coriolis force and the Centripetal Force
volVectorField Fcent = (Omega ^ (Omega ^ mesh.C()));
tmp<fvvectormatrix> UEqn
fvm::div(phi, U)
+ turbulence->divR(U)
+ (2*Omega ^ U)
+ Fcent
In the above case, all the cell centres follow a circular trajectory.
My question is regarding the shaking motion. The object is placed on a platform which shakes with a given frequency and amplitude. I have attached a sketch for clarity. As can be seen from the sketch , a point on the circumference of the object doesn't follows a circular trajectory.
I guess the term:
has to be changed as messh.C() varies and depends on the angle of rotation.
Does any body have a clue how the Fcent has to be modified to properly model such kind of behaviour.
With best Regards
Jaswinder
jaswi is offline   Reply With Quote
Old   July 19, 2007, 10:23
Default Hi, Jaswinder, Yes, I looke
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Jaswinder,
Yes, I looked into this type of motion before. Basically, you have to decompose force in X-direction and in Y-Direction (assuming a 2D case in X-Y). Based on omega, you should know the position of the object, i.e., (x, y) as a function of time. Then, do two derivatives to computation acceleration, then, multipy by mass to get Force as function of time.
Pei
hsieh is offline   Reply With Quote
Old   July 19, 2007, 22:44
Default Thanks Pei Shall give it a
Thanks Pei
Shall give it a try.
Regards
Jaswinder
Modeling of airfoil rotary motion Agni FLUENT 0 November 24, 2008 03:43
Mesh motion Samuel CFX 2 October 1, 2007 10:48
Dynamic Mesh _ Rotational Motion of a Rigid Plate ROOZBEH FLUENT 2 January 30, 2007 00:02
C.G. Motion Giuseppe FLUENT 0 January 24, 2006 13:02
WALL MOTION caloggero FLUENT 0 June 10, 2003 07:53
