Pitz Daily Test Case temperature measurements |
May 8, 2006, 10:09 |
Dear all,
I am interested i
Daniele Panara
Rep Power: 17 |
Dear all,
I am interested in the Pitz Daily test case. And in particular in temperature profiles. I have noticed that in the paper of Weller et al. (27th Symposium on Combustion,1998, pg 899-907) the numerical temperature profiles are compared with experimental data from Pitz and Daily (AIAA Journal 21-11,1983 pg 1565-1570), but in the above mentioned article I could not find any temperature measurements. Do temperature measurements for the Pitz Daily case exist? if yes what is the right reference? Thanks in advance, Daniele |
May 9, 2006, 13:16 |
I am also interested in the Pi
I am also interested in the PitzDaily case.
I run the Xoodles\pitzDaily3D, use the default 'combustionProperties' value. and run Xoodles\pitzDaily, set 'ignite' is 'yes',but the two cases do not ignite and combustion. when I increase the value of 'strength' of 'ignitionSites' to 200, the cases ignite,but reach error soon, "attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = 192.877 " I wonder how to run the cases pitzDaily3D and pitzDaily with combustion? what are the meaning of the following Properties? when 'strength' is '2', means how high temperature? and what is the 'ignitionSphereFraction' , 'ignitionThickness' and 'ignitionKernelArea' ? thanks ! qf -------------------------------------------------- ignitionSites ( { location (0 0 0); diameter 0.003; start 0; duration 0.001; strength 2; } ); ignitionSphereFraction 1; ignitionThickness ignitionThickness [0 1 0 0 0 0 0] 0; ignitionCircleFraction 0; ignitionKernelArea ignitionKernelArea [0 2 0 0 0 0 0] 0; ---------------------------------------------------- |
March 22, 2007, 03:00 |
Any News here ?
O R
Rep Power: 17 |
Any News here ?
3d test case | Hassan Raiesi | Main CFD Forum | 1 | August 19, 2006 12:33 |
Test Case | ganesh | Main CFD Forum | 0 | March 16, 2006 12:34 |
Looking for test case | William M. | Main CFD Forum | 2 | May 26, 2005 03:45 |
test case? | lsm | Main CFD Forum | 0 | June 14, 2004 11:39 |
test case | Follet | Main CFD Forum | 0 | July 8, 2002 04:07 |
