Arbitrary cyclic patch
Old   November 2, 2006, 04:58
Default Hi, I need to manage mesh w
Luca M.
luca is on a distinguished road
I need to manage mesh with cyclic patch. The problem is that I cannot use couplePatch utility because of are no integral cyclic patches. It's possible in OF to manage "Arbitrary" cyclic patch or do you have suggestions about it?!
Luca
luca is offline   Reply With Quote
Old   November 3, 2006, 03:51
Default Arbitrary cyclics do not exist
Mattijs Janssens
mattijs is on a distinguished road
Arbitrary cyclics do not exist. Any matching (to create cut faces) should be done as a preprocessing step. There is no ready made tool in OpenFOAM to do this. You might be able to program something like:
- create an offsetted mesh (transformPoints)
- merge the original and offsetted mesh (mergeMeshes)
- create overlapping region (stitchMesh)
- remove the offsetted region (subsetMesh)
- duplicate the cut faces from stitchMesh to the other side of the geometry (missing tool)
- create cyclics (createPatches)
mattijs is offline   Reply With Quote
Old   November 3, 2006, 06:45
Default Actually, there is work going
Hrvoje Jasak
Actually, there is work going on on this but it is not released into the public domain. There are 2 ways of doing this, one of which works on the originl mesh and another that performs face cutting using my sliding interface tools.
Hrv
Hrvoje Jasak
Old   November 6, 2006, 03:14
Default Thanks a lot for your suggesti
Luca M.
Thanks a lot for your suggestions
Luca
Old   December 20, 2006, 11:24
Default Hi Mattijs, I'm trying to fol
cosimo bianchini
cosimobianchini is on a distinguished road
Send a message via Skype™ to cosimobianchini
Hi Mattijs,
I'm trying to follow your suggestions on how to modify cyclic patches to obtain OneToOne correspondence between the faces on different patches enabling the match as cyclic patches.
Apart of the missing tool (copy the slave patch of the stitchMesh on the master one), I'm stuck on how to remove the mergedMesh from the mesh itself.
I don't understand how to define the <set> argument in the subsetMesh command line.
Thank you very much for your explanation
Cosimo
Cosimo Bianchini
Ergon Research s.r.l.
Via Panciatichi, 92
50127 Florence - ITALY
Tel: +39 055 0763716
Mob: +39 320 9460153
e-mail: cosimo.bianchini@ergonresearch.it
URL: www.ergonresearch.it
cosimobianchini is offline   Reply With Quote
Old   December 21, 2006, 17:50
Default The argument to subsetMesh is
Mattijs Janssens
The argument to subsetMesh is a cellSet. cellSets can be defined using the cellSet or setSet utility.
Have a look at e.g. boxToCell in the sample cellSetDict in the cellSet source directory.
Changing Temperature in Cyclic patch panara OpenFOAM Running, Solving & CFD 3 March 30, 2011 11:28
Arbitrary Cyclic beta code luca OpenFOAM Running, Solving & CFD 0 June 13, 2007 10:10
Cyclic patch in parallel calculations didomenico OpenFOAM Running, Solving & CFD 4 March 7, 2007 05:46
how to patch liquid to an arbitrary zone? Yi Qu FLUENT 1 November 17, 2005 02:23
Cyclic Boundaries -> Match Option -> Arbitrary Derek Siemens 1 August 4, 2004 22:06
