Problem Running Dynamic Mesh
Old   July 19, 2010, 08:13
Default Problem Running Dynamic Mesh
John Wang
cwang5 is on a distinguished road
Hi guys,
I've been having some weird problem with dynamicMeshDict setting for a customized solver. The solver I'm using is a point/cell displacement based motion solver, and I've tried just about every setting that I can used to get the mesh moving. The moving patch itself will move as per the pointDisplacement field specified, but nothing else moves at all. Attached are the pictures of the initial patch position and the position of the flap right before the solver crashes as the grids fold into each other.
The moving patch in question "flap" is a rigid surface attached to the upper-rear end of a block, and the motion was induced by the pressure difference across the flap. I am currently using the displacementLaplacian solver, and have tested the diffusivity setting of uniform, quadratic inverseDistance 1(flap), quadratic inversFaceDistance 1(flap), exponential 1 inverseFaceDistnace 1(flap), linear inverseDistance 1(flap), directional (0.1 0.1 0.1). I would appreciate if someone can provide some insight into the setting of dynamicMeshDict or a link to a site that contains the information.
Thanks a lot,
John
p.s. My OF version is 1.7.x
cwang5 is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 21:17
Problem with Dynamic Mesh and Fluent Claude Main CFD Forum 0 December 12, 2006 06:03
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 06:44
